Check Engine Light...
Old Jan 10, 2005 | 07:14 PM
mikester_91's Avatar
Default Check Engine Light...
So after cleanin off the screen on my IACV the other day....after about 15 minutes of driving my check engine light came on....and at low rpm's when i was giving it a little gas it was cutting out...I need a valve lash adjustment if that has anything to do with it, but i don't think that would cause the CEL to come on would it..
Old Jan 10, 2005 | 07:58 PM
@ries's Avatar
Default Re: Check Engine Light... (mikester_91)
did you happen to check the code for the cel? that could help us help you.
Old Jan 10, 2005 | 08:34 PM
MeUglyDuckie's Avatar
bad o2 senor?
Old Jan 10, 2005 | 09:04 PM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikester_91 &raquo;</TD></TR><TR><TD CLASS="quote">So after cleanin off the screen on my IACV the other day....after about 15 minutes of driving my check engine light came on....and at low rpm's when i was giving it a little gas it was cutting out...I need a valve lash adjustment if that has anything to do with it, but i don't think that would cause the CEL to come on would it..</TD></TR></TABLE>
pull the code and see what it's throwing. double check to make sure that you plugged the connectors all the way in.
Old Jan 11, 2005 | 05:20 AM
I tried checking the code with just the ignition on without the car running, and of course there was no check engine light on, cuz it doesn't come on till i start driving it for awhile. So...do i need to wait till it comes on and park the car while it's running and plug in the connectors?
speed_demon018
Mar 12, 2010 06:47 AM
egturbolsvtec
Mar 15, 2006 03:20 PM
idriveadelsol7
Aug 29, 2005 09:29 PM
97gSrkId88
Mar 20, 2003 11:06 PM
wm5holla
Mar 15, 2003 12:40 PM
