h23 crower cam specs! no more searching! - Honda-Tech - Honda Forum Discussion
Old 01-05-2005, 04:26 PM   #1
hOndafienD 04's Avatar
Default h23 crower cam specs! no more searching!
oem:
duration @ .010"
in:240 degrees
ex:240 degrees
duration @ .050"
in:183 degrees
ex:183 degrees
lobe lift:
in: .224"
ex: .224"
gross lift:
in: .414"
ex: .414"
stage .5 (stock replacement with similar specs to oem)
duration @ .010"
in:246 degrees
ex:250 degrees
duration @ .050"
in:190 degrees
ex:194 degrees
lobe lift:
in: .226"
ex: .218"
gross lift:
in: .418"
ex: .403"
Stage 1:
duration @ .010"
in:245 degrees
ex:251 degrees
duration @ .050"
in:193 degrees
ex:198 degrees
lobe lift:
in: .238"
ex: .228"
gross lift:
in: .440"
ex: .422"
stage 2 Turbo:
duration @ .010
in:245 degrees
ex:245 degrees
duration @ .050"
in:193 degrees
ex:193 degrees
lobe lift:
in: .238"
ex: .238"
gross lift:
in: .440"
ex: .440"
stage 2:
duration @ .010
in:250 degrees
ex:250 degrees
duration @ .050
in:211 degrees
ex:210 degrees
lobe lift:
in: .241"
ex: .235"
gross lift:
in: .446"
ex: .435"
stage 3:
duration @ .010
in:255 degrees
ex:255 degrees
duration @ .050
in:215 degrees
ex:215 degrees
lobe lift:
in: .244"
ex: .244"
gross lift:
in: .451"
ex: .451"
stage 2+ you will need the spring and retainer upgrade
Modified by hOndafienD 04 at 11:04 PM 1/5/2005
hOndafienD 04 is offline   Reply With Quote
Old 01-05-2005, 04:50 PM   #2
Default Re: h23 crower cam specs! no more searching! (hOndafienD 04)
my lift still bigger then the stage 3's
DLB1994 is offline   Reply With Quote
Old 01-05-2005, 04:56 PM   #3
post the type of cams and specs
Old 01-05-2005, 05:07 PM   #4
Default Re: (hOndafienD 04)
cant give specs but brian at crower did the grinding for me to the specs i gave him its a mid and highend cam only pulls to 8grand with a stock nonvtec head no porting or any thing
sorry cant give specs , it wont free to find out what kinda power band i needed for dragracing and what my head will take
put it this way i went thru many sets of valve seals try to get it right lol
Old 01-05-2005, 05:09 PM   #5
Hawkze_2.3's Avatar
Thanks for that info When did the turbo cam come out?!?!
Hawkze_2.3 is offline   Reply With Quote
Old 01-05-2005, 05:24 PM   #6
i dunno but i got the specs from some guys and its on a crower sheet...they even have a stock cam yet a little more aggresive....its a stage between oem and stage 1....so umm .5? lol i'll post that later.
Old 01-05-2005, 08:05 PM   #7
stage .5 specs as i will call them is up!
Old 01-05-2005, 08:14 PM   #8
PirateMcFred's Avatar
I measured my STOCK cams as this:
stock 1993 H23A1 cams:
Measured at 0.050" lift.
Intake opening (BTDC)
-21° (so that is 21° ATDC)
Intake closing (ABDC)
24°
Duration: 183°
Exhaust opening (BBDC)
30°
Exhaust closing (ATDC)
-20° (20° BTDC)
Duration: 190°
Gross valve lift measured w/1.67 rocker ratio
Intake @ cold .003" clearance:
~0.370"
Exhaust @ cold .006 clearance:
~0.370"
PirateMcFred is offline   Reply With Quote
Old 10-09-2005, 05:01 AM   #9
jdmaek's Avatar
Hi im looking to buy a pair of crower stage 1 camshafts, do u know if crower has any offical retailers or do they only sell direct. Becuase i tried looking for their prices and could not find any stores that sells h23 cams.
jdmaek is offline   Reply With Quote
Old 10-09-2005, 09:22 AM   #10
Hawkze_2.3's Avatar
Default Re: h23 crower cam specs! no more searching! (jdmaek)
Quote:
http://www.google.com
Crane Cams Stage 3 All Motor All DOHC VTEC B-Series Sunrise City Rider For Sale 4 01-20-2012 01:08 PM
Aftermarket cam specs list for D16A6. fastcrxsi90 Honda CRX / EF Civic (1988 - 1991) 52 08-30-2010 07:01 PM
Z6 cam vs. Y8 cam...Good Info!! boost and bass Honda Civic / Del Sol (1992 - 2000) 11 04-13-2009 05:18 AM
Skunk2 Pro 1 cams (b-series) "other recommended camshaft specifications" at what lift? rh76pogi All Motor / Naturally Aspirated 4 07-23-2008 07:15 AM
Cam Specs: Toda, Spoon, Skunk2, ITR, CTR TRuST Acura Integra Type-R 21 02-15-2003 06:03 PM
Tags
cam, cams, camshaft, camshafts, civic, crower, duration, ex194, h23, honda, prelude, spec, specs, stage, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
