how to remove secondaries?
as the title says...how do you do it? i took out my upper half of the manifold off today and i couldnt figure out how to remove te secondaries....can any1 please help? thanx
just take out the plate and bolt the upper half right onto the lower half? damn...thats easy i thought you took the butterflies out...dumb me...thanks anyways....and im removing them just to try thing out
The diaphram might get stuck on the FPR depending on what fuel rail you're using... mine did. A new gasket might be a good idea, I belive they're the same part (top and bottom gasket) so you only need one.
Also, the lost plenum volume might have a negative impact on head flow.
Adi
Adi
you just remove th plate and then put the top part of the intake mani back on,
i can deffinatlye say this is going to hurt your bottom end, and any gains up top are going to be small if any.
honda put the butterflies in for a reason.. just remember that
you just pull it off like everyone said, however removing the plate shortens your runner length which leads to less volume which is equal to less mass which is less force which means your intake charge has less force coming into the combustion chamber so after BDC it will not continue to force as much air into the cylinder, I also removed my butterflys but i would not recommend it for most people especially with an h23, the only reason I have mine removed(which i might not even keep it that way) is to see if there are any gains to be made on a highly modified setup on the top end
I don't know much about intake manifold sizing except that it's very complex, and that small changes runner or plenum shape/length/volume can have tremendous effects on engine output characteristics.
In theory though, the lack of butterflies should cause for less restriction and some top end gains. BUT what if that same restriction causes a kind of turbulance that results in more efficient filling of the combustion chamber and better fuel atomization?
Still though, you spend less than 1% of you time above 6000rpm and a lot more under 3500rpm, so why sacrifice city driving? Just my two cents.
Adi
Adi
we did this to my boys accord with a 22. we got a little bit more top end, no effect on the bottom end. it does suck up more gas though. not needed really just port and polish the head and port match the manifold to the head. get your throttle body bored this is more money but bigger gains.
boosted ek
Jun 27, 2005 07:01 PM
kinvid22
Jul 13, 2004 11:14 PM
