Bleeding the coolant system.
Old Jan 9, 2005 | 10:24 AM
mikester_91's Avatar
Default Bleeding the coolant system.
Alright, I found the bleed bolt....but there is No way in hell i can get that bastard off, becaus there's a vaccum hose right above it making it inaccesible to a wrench, socket, or pliers....i tried like hell to get the vacuum hose off but it won't budge....what to do now??
Modified by mikester_91 at 8:12 PM 1/9/2005
Old Jan 9, 2005 | 11:08 AM
britishlude's Avatar
Default Re: Bleeding the coolant system. (mikester_91)
Just let it run up to full temp for 5 mins with the radiator cap off and the heater in the car on hottest position, then top up the radiator as the air is released and replace the cap. That's the way I bleed mine.
Old Jan 9, 2005 | 11:39 AM
BrokeLude's Avatar
I don't think that's the right valve, as there shouldn't be any vacuum connection there. The correct one is behind where the top radiator hose connects to the block, and under and a little in front of the coil.
Old Jan 9, 2005 | 01:58 PM
SKDRCR's Avatar
Default Re: Bleeding the coolant system. (BrokeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeLude &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that's the right valve, as there shouldn't be any vacuum connection there. The correct one is behind where the top radiator hose connects to the block, and under and a little in front of the coil.</TD></TR></TABLE>
Yep, sounds like he's looking in the wrong place.
Old Jan 9, 2005 | 07:09 PM
I'm almost positive that this is the right bolt. It has a hole on the top for bleeding....and it's in front of the coil....like looking at the engine...it would be closer to the firewall than the coil. Remember, this is on an H23...
Old Jan 9, 2005 | 07:57 PM
SKDRCR's Avatar
Default Re: (mikester_91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikester_91 &raquo;</TD></TR><TR><TD CLASS="quote">I'm almost positive that this is the right bolt. It has a hole on the top for bleeding....and it's in front of the coil....like looking at the engine...it would be closer to the firewall than the coil. Remember, this is on an H23...</TD></TR></TABLE>
You should be looking for #14 in the picture
xlusiveracer
30
Feb 10, 2017 11:49 AM
Psycho719
Oct 30, 2011 01:51 AM
PatrickGSR94
Aug 19, 2008 03:48 AM
bokals
Mar 8, 2007 07:04 PM
max8455
Jan 10, 2005 05:04 PM
