technical question...
Old Jan 11, 2005 | 04:20 PM
hooddub's Avatar
Default technical question...
buddy of mine has a 93 lude with the h23. its blowing oil out of the tube on the valve cover. the one that is supposed to go to the intake tube. he has one of the little filters on it. anyway he drove about twenty miles and lost 1/2 quart of oil. any suggestions?
Old Jan 11, 2005 | 04:23 PM
Dougs96SI's Avatar
Default Re: technical question... (hooddub)
Take off the breather filter and reconnect the stock tubing.
Old Jan 11, 2005 | 04:27 PM
Hawkze_2.3's Avatar
Do a compression test after you put the stock tube back on. Normally oil doesn't come out of there...
Old Jan 11, 2005 | 04:30 PM
satan_srv's Avatar
Default Re: technical question... (Hawkze_2.3)
is the pcv valve connected and working on the other side? blocked??
Old Jan 11, 2005 | 05:20 PM
hooddub's Avatar
Default Re: technical question... (satan_srv)
ok we figured it out . the guy who he got the car from (2 weeks ago) put the wrong pcv on so it had the wrong pressure specs. thanks guys!
Cho0se
May 14, 2014 11:14 AM
JETSWU87
Mar 10, 2005 05:50 PM
UNDER PRESSURE
10
Oct 1, 2003 07:25 AM
1fstevo
Jan 27, 2002 02:08 PM
