Removing TPS Sensor?
Old Jan 10, 2005 | 03:36 PM
fassassin's Avatar
Default Removing TPS Sensor?
Does anyone how to remove the TPS from the TB? I am having trouble with it and it is on a 92 prelude si.
Thanks for the space.
Old Jan 10, 2005 | 03:38 PM
hon-derr's Avatar
its easy, there are two things that look like rivets that hold it in, cut a slot in both of them with a dremel, then unscrew them
Old Jan 10, 2005 | 03:58 PM
fassassin's Avatar
Default Re: (hon-derr)
Thanks!
Old Jan 10, 2005 | 06:03 PM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hon-derr &raquo;</TD></TR><TR><TD CLASS="quote">its easy, there are two things that look like rivets that hold it in, cut a slot in both of them with a dremel, then unscrew them</TD></TR></TABLE>
Old Jan 16, 2005 | 02:35 PM
Xsi's Avatar
Xsi
Make sure the problem is actually the tps before you remove it, you will nee to set it properly when you put it back on
Acidcrakker
Mar 29, 2008 05:54 PM
CRX30436
Feb 6, 2008 07:00 PM
foam
Jan 8, 2006 07:03 PM
JDM MonopolyMan
Oct 15, 2005 12:53 PM
killa_lude
Dec 26, 2003 04:52 PM
