Doesnt start sometimes
Old Jan 7, 2005 | 05:32 AM
bseries_beast's Avatar
Default Doesnt start sometimes
Sometimes my car doenst start. Its not all the time ill go to turn on the car turn the key and nothing. It doenst even try to turn over. I usually just keep tryin in tryin no noise or any thing and sometimes it just starts others i have to keep tryin. Would this be my starter or what?
Old Jan 7, 2005 | 06:11 AM
Filthy Focker!'s Avatar
Default Re: Doesnt start sometimes (krazie4vtec)
Probably not...
You say you turn the key and nothing happens. DO you mean it does not click or anything?
When you turn the key, have you noticed if any electrical components work also like the radio or something.
It could very well be:
1. electrical connection to the starter are bad
2. ground strap from battery is bad
3. ignition switch is bad
fs
Old Jan 7, 2005 | 06:44 AM
Default Re: Doesnt start sometimes (filthy_shovel)
No all my electrical stuff comes on like radio and everything.
Old Jan 7, 2005 | 06:57 AM
Next time it does this, check to see if you have electrical power going to the starter when the key is turned.
fs
Old Jan 7, 2005 | 07:40 AM
graphic's Avatar
check the battery wire...
i had the same problem cause i relocated the battery to the trunk and when i split the positive wire...and reconnected it ...connection wasn't really good...so occasionally same problem would happen to me..
go to start and nothing...no starter click or nothing only thing i really heard was a multiple relay click...probably from the (ELD) electronic load detector..
but once i re-did the connection w/ copper and soldier it never happened again...
start here..
Old Jan 7, 2005 | 08:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie4vtec &raquo;</TD></TR><TR><TD CLASS="quote">No all my electrical stuff comes on like radio and everything.</TD></TR></TABLE>
Well, if all your electrical stuff comes on, then we can safely say that electricity is flowing from the battery all the way to the switch and to the electrical components like the radio.
So then, the problem could be the circuit from the switch to the starter.
If, when the switch is at the start position, and you do not hear at least a click from the starter, and btw your battery is fully charged, then measure if you have voltage to the starter. If not, you found your problem. if yes, you found your problem also.
fs
Old Jan 7, 2005 | 09:06 AM
PrettyLude's Avatar
pretty well explained, the ignition switch might be the culprit
Old Jan 7, 2005 | 09:17 AM
funkmasterchipz's Avatar
Default Re: (PrettyLude)
it could be the clutch/neutral safety switch is going bad or u just have to push the clutch in before starting it up
Old Jan 7, 2005 | 10:14 AM
JDMSloLude's Avatar
Default Re: (funkmasterchipz)
I had a very similar problem and tested all switchs. My problem ending up being a tiny split in the wire to the starter. It was a real bitch but I would look there first and then to the ignition switch.
good luck
Ryan
Old Jan 7, 2005 | 10:15 AM
Jagan'92's Avatar
...or it could be the main relay under the dash. Next time you turn on the car, turn the key to acc, and notice how you see the lights on the dash come on, then you hear a click from under the dash as the abs lights and such turn back off.
when you start the car, you'll hear that same click again. that's the main relay.
When your car refuses to start, do you ever hear that first click? If not, I'd say it's your relay. When mine went out, I could push the brake pedal and get all kinds of weird clicking noises from the relay. anyhow, do a search for main relay and you'll find how to repair it, if you think it's the problem.
JDMpress
Mar 26, 2005 10:07 PM
es_squared
Oct 16, 2004 02:10 PM
EF9 JAMS!!!
Sep 23, 2004 10:21 AM
mingchi69
Jul 14, 2003 06:14 PM
junya16
Feb 26, 2003 08:31 AM
