test pipe question?
Old Jan 7, 2005 | 02:49 PM
jfingers's Avatar
Default test pipe question?
If i put a straight pipe to replace my high flow cat and make holes and get adapters to plug in my o2 sensors will my CEL come on? and if the light would still come on would that cause my atts light to come on to?
Old Jan 7, 2005 | 02:55 PM
bb6h22a's Avatar
Default Re: test pipe question? (jfingers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfingers &raquo;</TD></TR><TR><TD CLASS="quote">If i put a straight pipe to replace my high flow cat and make holes and get adapters to plug in my o2 sensors will my CEL come on? and if the light would still come on would that cause my atts light to come on to?</TD></TR></TABLE>
Yes.
Even if your 2ndary O2 is in the test pipe, it'll still trigger a CEL.
To run a test pipe, you need to run an OBD1 ecu.
Old Jan 7, 2005 | 03:09 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: test pipe question? (bb6h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a &raquo;</TD></TR><TR><TD CLASS="quote">
To run a test pipe, you need to run an OBD1 ecu.</TD></TR></TABLE>
no u can wire in a o2 sim and u wont get a cel
Old Jan 7, 2005 | 03:10 PM
bb6h22a's Avatar
Default Re: test pipe question? (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">
no u can wire in a o2 sim and u wont get a cel</TD></TR></TABLE>
It only lasts for a couple weeks at best, then you get one anyway.
I've tried on a prelude and an ITR - the CEL gets cleared, drive around for a week or so, BOOM CEL.
Though, you're right, I just imagined it in my head...........
Old Jan 7, 2005 | 03:14 PM
PrettyLude's Avatar
if its an obd2 it will trigger a check light for catalyst inefficiency, to remedy this problem get an o2 sim, with that the ecu will think that everything is ok, and no more check light
Old Jan 7, 2005 | 03:48 PM
TypeR0207's Avatar
Default Re: (PrettyLude)
I think there are plenty of people who have had good success with O2 sims, just ask around.
It might be the type of one that you put on, I have heard there are two different types. Supposedly the one KTeller sells is better and more accurate sim.
I will be buying mine in the next few days to install with my cheapy fleabay test pipe, so I'll find out as well.
Old Jan 7, 2005 | 04:23 PM
jfingers's Avatar
Default Re: (TypeR0207)
what is a sim? and will i get a atts light on as well if my check engine light does come on? i have a sh
Old Jan 7, 2005 | 04:26 PM
PrettyLude's Avatar
try and get a casper's electronics one, its plug and play
Old Jan 7, 2005 | 04:27 PM
darkd1gt's Avatar
Default Re: (jfingers)
wouldnt it be cheaper in the long run to just convert to odb1 just an option thrown out there or get hondata
Old Jan 7, 2005 | 04:42 PM
PrettyLude's Avatar
not really considering the price, casper's is around 70 bux, obd you would need a conversion harness and ecu
Old Jan 7, 2005 | 09:17 PM
jfingers's Avatar
does anyone know if my atts light will come on if my CEL light comes on?
Old Jan 21, 2005 | 01:26 AM
DC2 BoZz's Avatar
what exactly does a test pipe replace??? the resinator or the cat??
Old Jan 21, 2005 | 04:13 AM
Under_Pressure's Avatar
Default Re: (DC2 BoZz)
Cat.----/\
Old Jan 21, 2005 | 04:55 AM
Revi's Avatar
Default Re: (92h22alude)
A test pipe will replace your catalyc converter. More than likely your ATTS light will come on along with your Engine light because it is programed to do so even though there is nothing wrong with the atts unit.
Old Jan 21, 2005 | 10:18 AM
DC2 BoZz's Avatar
Default Re: (Revi-Ra)
thanx for the quick info
Old Jan 21, 2005 | 10:21 AM
98TypeSH's Avatar
if you have an SH, just get an o2 sim. No point in swapping to OBD1 ECU and losing atts just for a test pipe.
the O2 Simulator sends a signal to the ecu so it thinks its still reading properly. Wire it up and call it a day.
mfzbike
Feb 10, 2006 02:06 PM
rbdynamics
Dec 15, 2005 05:46 AM
SlammedDC2teg
Oct 14, 2005 05:32 AM
TURBOED-TEG
Jun 24, 2002 09:19 AM
comptechgsr2000
May 9, 2002 07:36 PM
