What is this??
Old Jan 9, 2005 | 04:59 PM
darylfiend11's Avatar
Default What is this??
Under the dash on the passenger side. It looks like an airbox of some sort? Just wondering what it is and what it does.
Old Jan 9, 2005 | 05:16 PM
rothjpkb's Avatar
Default Re: What is this?? (darylfiend11)
should have somthing to do with your heat/ac
Old Jan 9, 2005 | 06:11 PM
Default Re: What is this?? (rothjpkb)
bump
Old Jan 9, 2005 | 06:14 PM
satan_srv's Avatar
take a picture
under the dash on the pass side from right to left is the Fan Blower motor, A/C evaporator and then it goes to feed all the heating ducts...it's all connected together
Old Jan 9, 2005 | 06:15 PM
warrick's Avatar
It is most likley the box that holds the A/C evaporator core. I think that is what it is called
Old Jan 9, 2005 | 06:16 PM
92hondalude's Avatar
take a pic
Old Jan 9, 2005 | 07:51 PM
Default Re: What is this?? (warrick)
Yes its the box with evaporator core. What exactly does it do? Does it effect heat as well as a/c?
Old Jan 9, 2005 | 08:13 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darylfiend11 &raquo;</TD></TR><TR><TD CLASS="quote">Yes its the box with evaporator core. What exactly does it do? Does it effect heat as well as a/c?</TD></TR></TABLE>
a/c only...I removed the core and blocked the holes through the firewall where it came through...put the plastic box back in and the air just passes through the space rather than through the evap for a/c purposes. the path is essential for the functioning of the heater but you can pull out the evaporator
Old Jan 9, 2005 | 11:10 PM
Default Re: What is this?? (satan_srv)
What is the "path" exactly sorry. I removed mine and of course it the box around the core cracked and broke so i have no heat. What did you plug the firewall with and what do i need to do to get my heat back?
Old Jan 10, 2005 | 06:19 PM
bump for a freezing idiot!
Old Jan 10, 2005 | 06:25 PM
hOndafienD 04's Avatar
you need to put that box back, and put duck tape where it cracked for now, and tape down the hole thats in the firewall...
rchid
Jan 19, 2011 11:28 PM
Choy
Mar 28, 2010 01:56 PM
grkblood13
11
Dec 5, 2008 07:50 AM
Pr0ject93hb
16
Dec 13, 2006 01:30 PM
The Hooligan
May 22, 2005 12:00 PM
