tps problems again
Old Jan 20, 2005 | 10:40 AM
diluted's Avatar
Default tps problems again
sup everyone. i've been having the tps CEL for quite some time now and i can't seem to fix it. i tried calibrating the sensor to ~0.50. my idle stayed calm and there was no cel. but when i go for a drive, the cel would come on at any random time, whether its 5 minutes into driving or even 20 minutes. then my idle starts staying around 900-1100 rpms. i even tried swapping another tps that i had onto it and calibrated that one. i dont know really know what else to do, and im kind of worried because i need to smog my car soon so i can register it. can anybody have any input??
-L
Old Jan 20, 2005 | 11:01 AM
street_ruler's Avatar
Default Re: tps problems again (diluted)
what year lude...waht code and if its a jumpy idle it might be a vaccum leak, or a bad TB gasket
Old Jan 20, 2005 | 11:32 AM
diluted's Avatar
Default Re: tps problems again (street_ruler)
its a 92 si, im getting a code 7 (tps). and its not a jumpy idle, it only goes to 900-1100 when the CEL comeso n.
Old Jan 20, 2005 | 11:50 AM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diluted &raquo;</TD></TR><TR><TD CLASS="quote">its a 92 si, im getting a code 7 (tps). and its not a jumpy idle, it only goes to 900-1100 when the CEL comeso n.</TD></TR></TABLE>
Stock or aftermarket tb?
Old Jan 20, 2005 | 04:40 PM
ok sop lets get this straight...
driving with NO CEL...out of nowhere it comes on...
then idles higher than normal between 900-1100
that it??
and its tossing a code 7 which is TPS...i have ethat same cody by the way...
that all the info???
is it a stock TB??
Old Jan 21, 2005 | 12:46 AM
diluted's Avatar
yeah you got it right, and btw its a stock TB.
plz help =/
Old Jan 21, 2005 | 02:51 AM
ludegetsmwet's Avatar
check the linkage and check your evap canister, i threw on an aftermarket tb and thought it was the tps and turned out to be the evap
Old Jan 21, 2005 | 08:10 AM
specialedition's Avatar
Default Re: tps problems again (ludegetsmwet)
does the tps bog and cause the car to stall when driving it only? If so check and make sure that the harness itself the little gray harness is untwined and the three wires that run to it are free are untangled -- mine did the same thing and it turned out to be that the harness was twisted which cause the tps to short and it would also cause the tps to jump around in voltage readings... hope it helps...
Old Jan 21, 2005 | 08:20 AM
Hawkze_2.3's Avatar
Default Re: tps problems again (specialedition)
Yeah, if the TPS is good, then check the wires and the connections.
Old Jan 21, 2005 | 10:35 AM
diluted's Avatar
my car doesn't have any hesitation nor does it stall. what exactly would cause the evap canister to mess up the tps??
ill check out the wires today.
-L
dragon_lowrider
Sep 22, 2010 10:55 PM
mafay2
Jul 13, 2005 11:52 AM
mafay2
Jul 4, 2005 06:35 PM
