For coolant flush
Old Jan 22, 2005 | 12:37 PM
LudeChild's Avatar
Default For coolant flush.. Need help
...How many bolts are there to drain? helms says drain coolant bolt where it provides a picture... looks like its next to the oil filter of a 5th generation is this coorrect, is this the bolt to drain coolant? and for the thermostat bleed bolt what side is it on, on a 5th gen (base), near the tranny (right side) or left? also helms manual for 5th gen, there is another plug for the radiator is this correcT drain this as well?
Old Jan 22, 2005 | 12:40 PM
hOndafienD 04's Avatar
1 plug....it should be on the other side of the lower radiator hose.....like the motor side...the hose is on the tranny side.
Old Jan 22, 2005 | 01:30 PM
showbiz's Avatar
Default Re: For coolant flush.. Need help (LudeChild)
Make sure you have your interior climate set to the heat position so you flush your heater core also.
Old Jan 22, 2005 | 01:31 PM
Default Re: For coolant flush.. Need help (sedanman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sedanman &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you have your interior climate set to the heat position so you flush your heater core also.</TD></TR></TABLE>
fiftyOne
Oct 17, 2012 02:56 PM
tico
May 11, 2009 03:16 PM
loudsubz
Aug 14, 2006 03:13 PM
Rain_man
Oct 31, 2003 07:36 AM
CivicBoi
Jul 27, 2002 10:49 PM
