VTEC DOES NOT WORK ....
Old Jan 24, 2005 | 05:12 PM
abolish415's Avatar
Default VTEC DOES NOT WORK ....
ok .. heres the deal ... i just swap a motor into my prelude 92 ... jdm h22a ... i installed everything .. no check engine light .. changed oil ... checked the vtec solenoid ... everything seems coo ... im running a stock h22a ecu ... p13 that is .... when i hit 4800 rpm the vtec does not kick at all ... any one have the same problem ?? dont wanna search ... cuz theres too much post ... but thanks if anyone can help i appreiate it ... !
Old Jan 24, 2005 | 05:19 PM
94h22a's Avatar
Default Re: VTEC DOES NOT WORK .... (abolish415)
but really, sounds like there is a problem with your ecu, but im not sure
Old Jan 24, 2005 | 05:21 PM
abolish415's Avatar
Default Re: VTEC DOES NOT WORK .... (94h22a)
u think its my ecu ??
Old Jan 24, 2005 | 05:22 PM
94h22a's Avatar
yea, does it sound like your engine is trying to do anything when you hit high rpm's?
Old Jan 24, 2005 | 05:25 PM
abolish415's Avatar
yeah like when i rev high .. going up 5000 rpm - 7200 rpm it moves slow like theres no power kicking ... at that point ... so yeah ...
Old Jan 24, 2005 | 05:27 PM
94h22a's Avatar
like you are loosing power?
Old Jan 24, 2005 | 05:29 PM
abolish415's Avatar
yup ... its like when i rev like going fast the rpm does not budge it goes slow and vtec dont engage ....
Old Jan 24, 2005 | 05:33 PM
94h22a's Avatar
well, then ecu would be my guess, are you sure that you wired it right, and did the vtec ever work when you first did the swap or has it always done this?
Old Jan 24, 2005 | 05:38 PM
abolish415's Avatar
yeah it worked before .... cuz i blew my old motor ... hydrolocked ... from sucking water from a huge puddle ... and got another jdm h22a motor ... yeah im thinking its my ecu too .. because i was using my friend chipped ecu ... it worked great but damn it runs too rich and kills gas .... i just want my stock ecu so i can save gas ... cuz it dont run as rich as the chipped one .. but if its that case then .. thanks 94h22a ..!
Old Jan 24, 2005 | 05:41 PM
94h22a's Avatar
np
Old Jan 24, 2005 | 05:45 PM
abolish415's Avatar
hey what kind of ecu you running on now ?? and how much miles u rack .. up ... does it run rich .. if i can ask ?
Old Jan 24, 2005 | 05:55 PM
94h22a's Avatar
p13, 24-26 mpg, runs perfect
Old Jan 24, 2005 | 06:22 PM
caLiH22A's Avatar
Are you guessing VTEC doesn't work because you see the RPM's moving slowly or cause you don't hear it? Does it hit off the rev-limiter at around 6500RPM when you try to run it to redline? If your VTEC didn't work and your car doesn't show any CEL for it then it's probably oil pressure. Do some more troubleshooting and see what happens.
Old Jan 24, 2005 | 06:25 PM
abolish415's Avatar
Default Re: VTEC DOES NOT WORK .... (caLiH22A)
alright ill chck the oil pressure ... thanks man for your help ..!
Old Jan 24, 2005 | 06:47 PM
Gerhard_001's Avatar
There are many parameters that the ECU needs to see in order to engage VTEC
1. Vehicle speed-Speed sensor
2. Oil Pressure-oil press sensor, oil too low, oil too old
3. Engine Temp-Coolant temp sensor, faulty thermostat
4. Vtec soleniod-Make sure it is connected. Make sure the wire is in the plug, I had the wire fall out of the plug on my VTEC soleniod (did not throw a CEL for some reason),everything looked physically fine and engine parameters looked fine when I scanned and monitored the ECU while driving it. Double and triple check.
Old Jan 24, 2005 | 07:53 PM
5200BB6's Avatar
Default Re: VTEC DOES NOT WORK .... (Gerhard_001)
limp mode? no cel?
Old Jan 24, 2005 | 09:54 PM
PrettyLude's Avatar
i thought the vtec crossover point is at 5500 rpms? why is it switching at 4800? am i missing something here?
illuzi0nz
Oct 29, 2006 02:00 AM
hondaaccord94
Apr 5, 2005 04:33 PM
Nyquil_Accord
Sep 28, 2004 09:36 PM
hman09
Feb 22, 2004 08:50 AM
wiber1
Mar 24, 2002 04:21 PM
