need quick, accurate, answer
Old Jan 21, 2005 | 07:51 PM
H22A4 Prelude's Avatar
Default need quick, accurate, answer
is this decent and will it throw me a CEL. if its not good, please post a link to a verified 2.5" cat for a 2001 base prelude that does NOT throw CELs. i have searched but some people say catco, some people say carsound some say magnaflow, i just need something to replace my stock one cause its bad. all i have is a greddy evo 2 exhaust right now for aftermarket components. thanks guys
http://cgi.ebay.com/ebaymotors...33629
Old Jan 21, 2005 | 07:53 PM
satan_srv's Avatar
Default Re: need quick, accurate, answer (H22A4 Prelude)
if you want to be sure, buy OEM
Old Jan 21, 2005 | 08:03 PM
Default Re: need quick, accurate, answer (satan_srv)
thats all fine, but i still want something to mate with the pipe size of the evo 2, i find it hard to believe that aftermarket cats are not as reliable as the OEM one. if there is one that provides better flow while still meeting OEM specifications for OBDII compliance, i would greatly appreciate some information.
Old Jan 21, 2005 | 11:40 PM
homesauce's Avatar
How can you not believe that aftermarket cats are not as quality as OEM ones?? You can get a carsound for 60 bucks, while OEM ones will cost over 200$. The main reason the OEM cats are so expensive is because of the precious metals like platinum used in the OEM cats. I doubt the 60$ aftermarket cat has precious metals needed to catylize pollutive gases. Just get OEM.
Old Jan 22, 2005 | 09:01 AM
Don Jefe's Avatar
Default Re: need quick, accurate, answer (homesauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">How can you not believe that aftermarket cats are not as quality as OEM ones?? You can get a carsound for 60 bucks, while OEM ones will cost over 200$. The main reason the OEM cats are so expensive is because of the precious metals like platinum used in the OEM cats. I doubt the 60$ aftermarket cat has precious metals needed to catylize pollutive gases. Just get OEM.</TD></TR></TABLE>
While you're absolutly correct, he needs a cat that will bolt up to a 2.5 inch diamater pipe. If im not mistaken, dont OEM cats have a 2 inch flange? Correct me if im wrong.
In any case, im wondering the same thing, im going to be doing a collector mod to a greddy header fairly soon, and i wanted to find a cat that would match the collector's piping size.
janek
Jun 24, 2010 06:21 AM
99ssinoc
Jun 30, 2007 06:50 PM
RiceBurninCX
Jun 27, 2007 01:31 AM
