Making the H23VTEC
Old Nov 9, 2005 | 03:31 PM
CAbbott87's Avatar
Default Making the H23VTEC
I currently have the H23 in my 92 SI and I will be getting a hold of an H22 very soon. I want to go with the H23VTEC swap. I'm going to Swap out the rotating mass from the h23 and get the rods and crank area polished along with buying new pistons. Im going to swap in the h23 rotating mass for the h22s and then rebuild the h22 block back together. I wanted to know if anyone had any type of information on this swap and if anyone had any advice on exactly what all needs to be done.
Old Nov 9, 2005 | 04:28 PM
ThE PiMpiN Co's Avatar
Default Re: Making the H23VTEC (CAbbott87)
nothing more needs to be done. just swap it in and leave the piston oil squirters in there, and have everything balanced. you should be good to go. also, swap over the manual tensioner while your at it. you should search before you post though, this topic has been covered lots of times, anyways, good luck.
Old Nov 9, 2005 | 04:32 PM
BB6racer's Avatar
Default Re: Making the H23VTEC (aRaBiAn RiCe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aRaBiAn RiCe &raquo;</TD></TR><TR><TD CLASS="quote">this topic has been covered lots of times</TD></TR></TABLE>
try the FAQs, theres an article about this under the "egine" section.
otsegolectric
Dec 3, 2007 05:23 PM
folta2169
Dec 16, 2004 09:59 PM
hondaguyef
23
Apr 25, 2004 03:40 PM
