CEL code 36
Old Nov 14, 2005 | 01:27 PM
Mad Hatter's Avatar
Default CEL code 36
i have a '92 Si, which i just swapped a jdm h22 into. When i got it back, my check engine light stared coming on...when i jumped the wire, it says i have a 23 and 36. i know the 23 is the knock sensor, but what is 36? i did a search and couldn't find the answer, except "anything not listed, replace the ecu". since its a jdm motor/ecu, does this code just mean i need to get it overridden by honda, or is it something serious. please help me out...
Old Nov 14, 2005 | 02:26 PM
Mad Hatter's Avatar
Default Re: CEL code 36 (i'm so lude)
bump
i went to autozone and they couldn't help me
EDIT: ok, nevermind its traction control
Old Nov 14, 2005 | 02:39 PM
staticrex's Avatar
The 36 code is a ghost code for the 4ws. I get the same code, but it will not light up unless another code is present.
Whenever you pull the codes you will get the 36. Doesn't hurt anything.
Old Nov 14, 2005 | 02:50 PM
Mad Hatter's Avatar
Default Re: CEL code 36 (staticrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex &raquo;</TD></TR><TR><TD CLASS="quote">The 36 code is a ghost code for the 4ws. I get the same code, but it will not light up unless another code is present.
Whenever you pull the codes you will get the 36. Doesn't hurt anything. </TD></TR></TABLE>
oh, ok. thanks for your help ...i don't get why autozone doesn't know these things...
97teg415
Jun 1, 2008 07:03 PM
djcue_530
Mar 15, 2007 08:53 AM
vtechrex
Jul 10, 2006 06:21 PM
cheezoto
May 10, 2004 11:43 AM
GeeSeeR
Aug 10, 2001 03:39 PM
