compression test
Old Nov 9, 2005 | 08:12 PM
01_prelude's Avatar
Default compression test
im getting ready to change my plugs, plug wires, ignition and intake this weekend. i want to do a compression test on the motor and find out what the motor is showing. does anyone know the specs its a 01 base lude
thank you
Old Nov 9, 2005 | 08:25 PM
H0ndaJunkie's Avatar
Default Re: compression test (01_prelude)
<U>Compression</U>
Note: @ 250 rpm and wide open throttle
Nominal 1270 kPa
Minimum 930 kPa
Maximum Variation 200 kPa
Old Nov 9, 2005 | 08:43 PM
01_prelude's Avatar
Default Re: compression test (H0ndaJunkie)
i need specs in ft/psi
Old Nov 9, 2005 | 09:03 PM
awww man, you can't do the math?
to find psi, we multiply the kpa by 0.14504
so.....
Nominal 184 psi
Minimum 134 psi
Maximum Variation 29 psi
Old Nov 10, 2005 | 01:24 PM
InvaderTrax's Avatar
184 on an H22 is actually kinda low. Most people I've seen get 200+ with a good engine
JConto
12
Feb 23, 2010 10:01 AM
EG6 Love
Feb 15, 2008 05:06 PM
TylerH
Mar 15, 2006 11:16 AM
crxvtecturbo
Feb 7, 2005 06:20 PM
brent_G
Oct 12, 2003 12:15 AM
