OBD2 to OBD1 conversion? Is it Possible? HELP!
Old Nov 11, 2005 | 09:51 PM
bigtimlikewhoa's Avatar
Default OBD2 to OBD1 conversion? Is it Possible? HELP!
Right now I have an OBD2 on my 5th gen lude (duh).. well I was wondering If I could convert it or make it think I have OBD1? because I'm soo sick of the damn CEL that turns on with those minimal almost no use sensors.. and especially I'm about to give Skunk2 IM a try.. I've been reading about them and it throws a CEL because of the EGR valve being disconnected.. on OBD1 CEL dont turn on but on OBD2 it does.. soo I was wondering if I could do OBD2 to OBD1.. I've seen and read about the different wire harnesses like OBD2 to OBD1 and OBD1 to OBD2 and what not.. Can I use those? or do those have a different purpose? alright.. I need help foreal! Thanks!
Old Nov 11, 2005 | 09:55 PM
veganej's Avatar
Default Re: OBD2 to OBD1 conversion? Is it Possible? HELP! (bigtimlikewhoa)
yes it is possible, however on you motor it would probably be more of a pain in the ***. you would want to get an obd1 ecu bc there is a crankshaft position sensor at the bottom which is read only on obd2 ecu's you would need to disconnect. rather you could probably leave it attached if you get an obd1 ecu since it wont read it anyway. you need to switch the injectors, dizzy, resistor box, and i think you can remove your egr valve. anyone correct me if im wrong
Old Nov 11, 2005 | 10:11 PM
98vtec's Avatar
moderator emeritus
Default Re: OBD2 to OBD1 conversion? Is it Possible? HELP! (veganstraightedge)
get an OBD conversion harness and a p28 or p72 ecu. Get the ecu chipped with an h22 basemap then go get the motor tuned.
Old Nov 12, 2005 | 06:02 AM
PRELUDE-GT35R's Avatar
go buy a Hondata and the harnesses to concert OBD1. And then get the shop tune you never see a CEL again
Old Nov 12, 2005 | 06:21 AM
zexifiedlude's Avatar
what the hell is a dizzy?
Old Nov 12, 2005 | 06:51 AM
The_Sober's Avatar
Default Re: (zexifiedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexifiedlude &raquo;</TD></TR><TR><TD CLASS="quote">what the hell is a dizzy?</TD></TR></TABLE>
you're kidding, right?
dizzy=distributor
Old Nov 12, 2005 | 06:38 PM
Default Re: (The_Sober)
Could someone give me a lesson on ECU types and what not.. I've tried searching and searching trying to learn about them but it seems like to me everyone just automatically knows about ECUs the way they talk about it.. What is the difference with different ECUs? some one help would be greatly appreciated! thanks a lot
Old Nov 12, 2005 | 06:57 PM
mgags7's Avatar
take a look around at hondata.com and pgmfi.org
you will find what you need to know....
the only problem with doing this conversion is inspection...
mobeast808
Jan 26, 2025 09:18 PM
ekb16
Feb 15, 2005 06:51 AM
92civic_si
16
May 6, 2004 02:50 PM
AllMotorITR
Jun 16, 2001 09:18 PM
