surface rust and what to do
Old Nov 10, 2005 | 09:48 PM
bboixtc's Avatar
Default surface rust and what to do
i have a 92 lude 4ws no rust at all however.
i got rear ended and my fiberglass bumper pushed up against the quarter panel kinda under the tail light.
a small amount of paint chipped off the rear quarter panel and now bare metal is showing. i put touch up paint in the mean time. but the parts i couldn't get to already started to rust.
so what i've been told is to buy 180 grit sand paper, sand down the surface and the rust away, and put something over it to prevent it from rusting then just put touch up paint over it.
what is that stuff that i'm supposed to put over the bare metal to prevent it from rusting? primer? metal sealant? anyone have a link of something that i can go buy at autozone? thanks.
Old Nov 11, 2005 | 04:10 AM
mgags7's Avatar
its called paint dude...sand, primer, paint....done....
why do you have fiberglass bumpers....they are urethane for a reason....
Old Nov 11, 2005 | 10:49 AM
h22_crx's Avatar
Default Re: (mgags7)
sand it down then if the rust is real bad get some all metal and put where the rust was
sand that down next use body filler and then primer then paint and clear
Old Nov 11, 2005 | 10:50 AM
h22_crx's Avatar
Default Re: surface rust and what to do (bboixtc)
do u have any pics of the rust
Old Nov 11, 2005 | 12:10 PM
user 9782082308's Avatar
Default Re: surface rust and what to do (h22_crx)
Technically, you're supposed to use epoxy primer to seal any bare metal. Regular primer is porus holding moisture from the air and getting sealed in when you spray the base/ clear. If you don't care about the rust coming back after a couple of years, go ahead with the regular primer.
stiness101
Apr 25, 2006 05:06 PM
HamiltonRex
Jul 17, 2004 06:13 PM
Beave0101
Jan 20, 2004 06:28 PM
JadeDM
Jul 28, 2003 06:08 AM
YeuEmMaiMai
Sep 6, 2002 02:41 PM
