slim fit radiator fan...
i recently purchased a koyo radiator...i need a different fan & fan shroud because the stock fan shroud doesn't line up with the bolt holes on the koyo radiator. im going to order from spal usa...as someone suggested previously. i was wondering whether i would need a medium profile 14 inch...or medium profile 16 inch fan....they knew nothing....any help would be awesome.
thnx!
thnx!
13" is right i have the same set up.....you probably got the info from one of my posts.
the 14" fan would slightly overhang the flow area on the top/bottom....so the benefits from the extra inch on the sides would be minimal.
i am using the smallest profile they have and don't need a shroud, that radiator is so efficient that the fan takes a while before it even needs to come on. I just have one 13" in the middle of the radiator because i removed the a/c.
^you could mount a slim fan on the stock with custom brackets but i don't know why you would want to
^^you can check, i think they have the volt specs of their fans at spal's website
^yeah just buy the custom brackets and mount them up and cut off the excess bracket.....i just bought the long ones and cut off the excess
truthfully you could make your own with some metal strips and a drill
Re: (Silver Surfer)
for extra room in the bay, mount your fans on the front of the radiator and wire them to be pull fans, just as proficienet and it saves a ton of room...
GRANT!
10-27-2009 03:37 PM
