How to tell what tranny?
Re: How to tell what tranny? (Rad Racing)
You mean where the bar code is on it or on another part of the tranny? because there is no bar code anymore.. just hoping i didn't get screwed on the tranny. i'll know when i get it in.. but is there anyway to tell from any other part of the tranny..?
Thanks,
Greg
Thanks,
Greg
the only #'s i found on the tranny are in the cast and they are PX5-3 this is located on the left side axle face if the tranny was in the car. its the place that looks like a web. anyways. i have an h23 tranny and a f22 tranny.. i compared and the old h23 tranny has the same code PX5-3 and the F22 tranny has PX5-5.. so i'm hoping that i didn't receive a h23 tranny again or i'm gonna be pissed cause i will have to wait yet another week.. maybe even two.
Re: (cazzbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cazzbo »</TD></TR><TR><TD CLASS="quote">The Gear Ratio's are and tranny arn't ment to be reved as high as a h22</TD></TR></TABLE>
i guess thats why i always grind when i try to shift past 7200 rpm. (f22 tranny with h22 engine)
1 Post
I really doubt you'd have problems with a good condition H23 transmission. I've always preferred taking each gear a little longer. Especially when you're making a lot of power
Re: (cazzbo)
IF its in the car lean over and look down. the tranny code is stamped in near where your barcode used to be. M2A4 comes with the h22a swap, just like mine did. Good tranny, also gear ratios are very similar on the h23a tranny so you wont be able to just tell by speed
Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">What's so bad about an H23 transmission?</TD></TR></TABLE>
nothing, but for people running N/A H22's, a lot of the time h23 trannys will drop them out of vtec because of the longer gear ratios.
