ATTS Fluid?
Old Dec 27, 2006 | 09:33 AM
SHPrelude00's Avatar
Default ATTS Fluid?
What kinda of fluid is supposed to be used in the ATTS unit? I'm pretty sure it's just Honda MTF but im not positive....and i can't seem to get a 'confident' answer from <U>ANY</U> "Honda Tech's" from the dealership ....
Modified by SHPrelude00 at 10:55 AM 12/27/2006
Old Dec 27, 2006 | 11:32 AM
lude98SH's Avatar
Default Re: ATTS Fluid? (SHPrelude00)
Its honda ATF
Old Dec 27, 2006 | 12:09 PM
Chuckles99SH's Avatar
Default Re: ATTS Fluid? (lude98SH)
ATF ftw.
Old Dec 27, 2006 | 12:37 PM
thelonerangers's Avatar
Default Re: ATTS Fluid? (Chuckles99SH)
how often do u have to change it and are there any write ups on how to do it?
Old Dec 27, 2006 | 01:47 PM
ATF is for an Automatic...
Old Dec 27, 2006 | 05:22 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHPrelude00 &raquo;</TD></TR><TR><TD CLASS="quote">ATF is for an Automatic...</TD></TR></TABLE>
It's not for your transmission, its for the ATTS unit.
Old Dec 27, 2006 | 05:59 PM
Default Re: ATTS Fluid? (mkazm83)
i know this... and thus this is why ATF (Automatic Transmission Fluid) probably isn't the right answer... read the post before commenting...
Old Dec 27, 2006 | 06:13 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHPrelude00 &raquo;</TD></TR><TR><TD CLASS="quote">i know this... and thus this is why ATF (Automatic Transmission Fluid) probably isn't the right answer... read the post before commenting...</TD></TR></TABLE>
Why don't YOU read all the above posts?
Old Dec 27, 2006 | 06:15 PM
mgags7's Avatar
Barnette.....you put ATF in the ATTS unit....unclog your semeney ears already....lol
Old Dec 28, 2006 | 04:29 AM
Default Re: ATTS Fluid? (bb4ever)
ok, thank matt? i guess... i just thought that ATF was supposed to be a thinner fluid and was only used in Automatics?... but if thats what we are to use, then thats what we are to use... thanks
Old Dec 28, 2006 | 04:46 AM
mgags7's Avatar
Old Dec 28, 2006 | 02:02 PM
lude98SH's Avatar
It is look in a helms or any other manual. Search through some posts also because i remember asking the same question about a year ago and I know i have seen many others ask the same question.
Old Jan 16, 2007 | 09:56 AM
arkosh.kovash's Avatar
* B A N N E D *
Helms says ATF.
Old Jan 16, 2007 | 02:01 PM
VTECnKEN's Avatar
Default Re: ATTS Fluid? (arkosh.kovash)
ATTS is essentially a tiny automatic transmission, it uses similar clutch packs and has a planetary gearset (you can see the parts for yourself in a thread a few pages back).
So, the use of ATF makes sense. It takes a little over a quart for a fill-up.
Old Jan 16, 2007 | 02:31 PM
1GPlusSH's Avatar
Correct. It is also for the ATTS unit. You can put any automatic transmission fluid in there, but I highly recommend Honda's.
Old Jan 16, 2007 | 02:38 PM
Revi's Avatar
Default Re: ATTS Fluid? (1GPlusSH)
All you mother F'ers are WRONG. Its 1 Qt of ATF.
Old Jan 16, 2007 | 02:55 PM
* B A N N E D *
Default Re: ATTS Fluid? (Revi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi &raquo;</TD></TR><TR><TD CLASS="quote">All you mother F'ers are WRONG. Its 1 Qt of ATF. </TD></TR></TABLE>
correct.... for fluid replacement. for fluid filling, done after you disassemble (Revi) or replace the ATTS, it is 1.5qt
Old Jan 16, 2007 | 03:10 PM
Revi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arkosh.kovash &raquo;</TD></TR><TR><TD CLASS="quote">
correct.... for fluid replacement. for fluid filling, done after you disassemble (Revi) or replace the ATTS, it is 1.5qt </TD></TR></TABLE>
Damn, OWNED.
Its a good thing it uses ATF fluid, that way you can tell what leak you have under your car. Engine, MTF or ATF.
Old Jan 16, 2007 | 03:51 PM
1GPlusSH's Avatar
So easy, even a caveman could do it.
Old Jan 16, 2007 | 04:04 PM
Revi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GPlusSH &raquo;</TD></TR><TR><TD CLASS="quote">So easy, even a caveman could do it.</TD></TR></TABLE>
Geico Caveman FTW
Old Jan 16, 2007 | 04:39 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi &raquo;</TD></TR><TR><TD CLASS="quote">Damn, OWNED.
Its a good thing it uses ATF fluid, that way you can tell what leak you have under your car. Engine, MTF or ATF. </TD></TR></TABLE>
not trying to own.. just spreading what little knowledge i do have. dont want that atts drying up on you.
anyway, you cavemen are all the same.
Old Jan 16, 2007 | 05:03 PM
madcatz's Avatar
caveman.....jack bauer...silly kittahs
whats hondatech comming to
Old Feb 10, 2007 | 06:30 PM
Cruiserdude's Avatar
It's definitely ATF, and I had understood it was 3 qts?
Old Apr 7, 2009 | 09:29 PM
Inextricabledrvr's Avatar
Sorry to bring up this thread again, but I just drained and filled my ATTS unit with over 1 qt of ATF. I couldnt get an exact reading of how much I put in there because the damn manual handpump would spill everywhere. Finally, after all the pain and suffering, I bought one of those suction pumps and squeezed it right in. (it took 30 seconds to get all of it in there)
My concern is the amount of fluid I put in there. I believe I put about a qt and a half. Will this harm the unit? I am not completely sure on how much I put in. Should I just put new fluid again to be sure?
And the main reason for me changing the oil is the ATTS light keeps popping up intermittently. I pulled the radio/clock fuse to reset the ECU as well.
Any help would be great...
Old Apr 7, 2009 | 10:13 PM
TheJGB3's Avatar
Here you go...the ATTS unit takes Honda ATF-Z1 fluid
