Should I plug this ?
Old Jan 2, 2007 | 04:44 PM
8_6 luder's Avatar
Default Should I plug this ?
I removed this thing for better air flow
from here
I now have a loose vaccum line that sucks air when the engine runs
It was connected to this valve
What should I do with this line ? Keep in mind that if I pull it and cap the end it will build pressure . If I leave it disconnected it will pull dirt and debris . Maybe I could pull the valve off of that big black thing reconnect it and place it somewhere else out of the way . Any Ideas ?
Old Jan 2, 2007 | 04:48 PM
Flip.'s Avatar
Default Re: Should I plug this ? (8_6 luder)
Just cap it off. It's just a vaccum line to open up a butterfly in the resinator(the thing you just removed)
You can remove the whole line and cap it off from the intake manifold if you want to clean it up a bit.
Modified by Flip01 at 11:59 AM 1/3/2007
Old Jan 2, 2007 | 05:05 PM
saikou's Avatar
Default Re: Should I plug this ? (Flip01)
Cap the nipple on the intake manifold.
You can also disconnect & remove the intake control solenoid valve.
Old Jan 2, 2007 | 05:31 PM
8_6 luder's Avatar
Default Re: Should I plug this ? (saikou)
Awesome , thanks alot guys .
SlimBB4
May 14, 2009 06:08 AM
chihuahuamanx
Feb 7, 2005 08:40 AM
DaX
Jun 4, 2004 09:19 AM
Joon525
Jun 17, 2003 08:13 PM
93H22ACX
Feb 9, 2003 03:37 PM
