help!
Old Jan 2, 2007 | 11:05 PM
maverik's Avatar
Default help!
searched all over already and nothing, so here it goes. i have an 01 lude. my slave cyl gave out so i replaced it, and also the master. with both being brand new, it still seems that there is air in the system, or maybe my clutch is giving out. i bled it as much as i could but when i start driving it, starts to loose pressure. any help is appreciated
Old Jan 2, 2007 | 11:13 PM
pprowler6's Avatar
Default Re: help! (maverik)
just a guess but could it be the clutch dampener?
Old Jan 2, 2007 | 11:18 PM
maverik's Avatar
Default Re: help! (pprowler6)
whats the clutch dampener? i was thinking maybe my pressure plate or throwout bearing went bad?? but i'm open for any suggestions
Old Jan 2, 2007 | 11:31 PM
importfanatic17's Avatar
What do you mean you bled it as much as you could?
Old Jan 2, 2007 | 11:35 PM
maverik's Avatar
Default Re: help! (importfanatic17)
well i could probably bleed it more but i bled until no more air bubble came up in the resivour. could be wrong though
Old Jan 2, 2007 | 11:43 PM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maverik &raquo;</TD></TR><TR><TD CLASS="quote">well i could probably bleed it more but i bled until no more air bubble came up in the resivour. could be wrong though </TD></TR></TABLE>
Maybe you typed that wrong, but you don’t look for air bubbles in the reservoir you look for air bubbles at the bleed valve at the slave
Old Jan 3, 2007 | 12:28 PM
Default Re: help! (CHK4TIX)
Yup. Bleed from the bleeder screw on the front of the slave. Pump the clutch until you don't see any more air bubbles and then hold the clutch down, and tighten the bleeder screw.
fasterthenmost
Feb 12, 2006 06:48 PM
ichiban_719
Nov 30, 2005 04:31 AM
4playEkay
Sep 21, 2005 11:46 PM
fridexter
11
May 27, 2005 01:19 AM
AllMTRWH0R3
Aug 4, 2004 02:09 PM
