Blown engine fix
I'm now considering fixing the SI vtec with the blown motor. The owner said he ran the oil low. If this is the case, how hard of a fix do you think it would be? I'm going to have a mechanic check it out this week but i was hoping for a little feedback so i know a little more going in.
if it was run low on oil, chances are the bearing are shot... and possibly the oil pump might have taken a dump. if you are rebuilding, have the crank inspected carefully, and do the routine stuff like new water pump, oil pump and pick up tube, and a fresh hone. new main bearings and rod bearing and make sure to check your clearances. honda has very tight clearances so be precise.
