weird power problem
Old Dec 29, 2006 | 08:57 AM
Ideal's Avatar
Default weird power problem
Hey guys, i was hoping you guys could help me out... I did some searching and just wanted to get some new opinions.
My Car has lost alot of power. I could be smashing the gas pedal and the accelaration is very slow. Ive been noticing more black soot on the end of my exhaust and bumper and there is a rattling sound underneath my car(sounds like its underneath my backseat). Through my research ive ran accross a couple of threads where it was, a bad cat, a bad o2 senser, a bad egr valve or bad timing. I was hoping someone might be able to shed some light on my problem.
Thank You
-Jonathan
Old Dec 29, 2006 | 09:27 AM
nonvteclude's Avatar
Default Re: weird power problem (Ideal)
i would check those things first, anyone of those things would cause loss of power. also when was your last full tune up.
Modified by nonvteclude at 11:52 AM 12/29/2006
Old Dec 29, 2006 | 11:00 AM
Skidtron89's Avatar
You need to check things that effect the fuel since you are running rich judging by your description. TPS, MAP, ECT, IAT. unless there is misfiring then check the distributor stuff instead
Old Dec 29, 2006 | 12:41 PM
Ideal's Avatar
Hey Guys, im pretty sure that its my catalytic converter, i took a look underneath... when I rev the car that loud rattling sound is comming from my cat.
Would that explain my power loss and while there is black soot over the tip of my exhaust?
Old Dec 29, 2006 | 12:55 PM
Lewdin' Incognito's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.thepartsbin.com/cat....html &raquo;</TD></TR><TR><TD CLASS="quote">A sure sign that your catalytic convertor is bad is when you can hear rattling noises emitting from the catalyst which has broken apart from the converter casing... </TD></TR></TABLE>
Looks like it's time for a new kitty.
it could be, if it was clogged then that would hurt your power
Old Dec 29, 2006 | 01:01 PM
Ideal's Avatar
Default Re: weird power problem (nonvteclude)
would it cause me to run rich though?
Old Dec 29, 2006 | 01:05 PM
i was just reading on it. you will have a rotten egg smell and the cat will heat up to the point that it turns red. didnt see anything about making it run rich. alos says that gas mileage will be horrible and you should be running with a check engine light
Old Dec 29, 2006 | 01:21 PM
Ideal's Avatar
any recommendations on a cheap carb-legal bolt on cat i can purchase? im doing research right now, but if anyone has anything off the top of their head let me know please
thanks for all of your help guys.
Jon
Old Dec 29, 2006 | 01:31 PM
Hawkze_2.3's Avatar
I recently got a Catco cat for my CRV and it was pretty decent and a bolt on for ~$130. If you want a good high-flow get a Carsound/Magnaflow.
austinkli
Feb 12, 2008 07:24 AM
EKB18BPR3
Apr 19, 2005 03:47 AM
reza"
Feb 20, 2005 03:42 PM
Voom
Aug 5, 2003 02:39 AM
Philip
13
May 7, 2003 10:43 PM
