clutch problem...???
Old Jan 4, 2007 | 03:51 PM
BB409's Avatar
Default clutch problem...???
alright so i was just driving last night and something really messed up in my 4th gen. i was shifting into 4ths and it was like i miss shifted. it popped out of 4th gear or something and i reved it up high, immediately putting my foot on the clutch then trying to put it into gear but it wouldn't go into any gear. the clutch was stuck at the florr so i pumped it up and got a little clutch and then i finally got it into 4th gear and tried to drive and immediately smelled the cluctch burning away so i turned off the car to let it cool. it still shifts into all gears fine with the car off. then i turned on the car and it shifted but as the car ran it got harder and hared to shift. then i reved the motor a little to make sure everything sounded fine and we still could smell the clutch burning. i think it was the master and slave cylinder that gave out. my hydraulics failed and the clutch was stuck engaged. it is at a shop and won't be worked on for a few days so i was wanting to see if anything like this has happened to anyone and what other parts can i expect might also be screwed up? it was also a napa clutch which i feal are pices of crap. i want an exedy this time around.
Old Jan 4, 2007 | 04:01 PM
Revi's Avatar
Default Re: clutch problem...??? (BB409)
Well the master and slave cylinders are easy to check to see if they are working, but it sounds like your pressure plate took a dump.
Napa clutch?.....
Old Jan 4, 2007 | 06:21 PM
GraphiteMW's Avatar
Default Re: clutch problem...??? (Revi)
NAPA
2000HondaEm1
Nov 24, 2009 04:09 PM
codybb4
Dec 9, 2008 08:44 AM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
RainingRed24
Oct 11, 2005 01:47 PM
flip1199
Jul 29, 2002 02:14 PM
