help me!!! disassembling block.
Old Jan 4, 2007 | 09:22 AM
bluedlude's Avatar
Default help me!!! disassembling block.
well i got an old H22A1 block for christmas from my girlfriend (best girl ever). and im trying to take it apart so i can get it hot tanked and probably honed. well i cant get the bearing cap bridge off, or the main caps for that matter. does anyone have any tips on that for me. ive never worked on a block before. thanks in advance.
Old Jan 4, 2007 | 09:24 AM
Revi's Avatar
Default Re: help me!!! disassembling block. (bluedlude)
You have to use some kind of plastic or wooden tool, like the handle of a wooden hammer and gently pry the girtle through all 4 corners. Work your way around it and pry it up, it will be on there pretty good. But once you break it loose it will come off easy.
Old Jan 4, 2007 | 09:25 AM
Revi's Avatar
Default Re: help me!!! disassembling block. (Revi)
dont use a screw driver or any metal object to do this as you could cause damage to the oil pan matting surface and everything else.
Oh yeah, becareful while working inside the block, the edges are SHARP as hell. I have learned this through the years the hard way.....
Modified by Revi at 1:44 PM 1/4/2007
Old Jan 4, 2007 | 10:49 AM
SHPrelude00's Avatar
definatly sharp as HELL!!! hahaha
Old Jan 4, 2007 | 01:01 PM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi &raquo;</TD></TR><TR><TD CLASS="quote">You have to use some kind of plastic or wooden tool, like the handle of a wooden hammer and gently pry the girtle through all 4 corners. Work your way around it and pry it up, it will be on there pretty good. But once you break it loose it will come off easy.</TD></TR></TABLE>
ill try this and let you know how it went.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHPrelude00 &raquo;</TD></TR><TR><TD CLASS="quote">definatly sharp as HELL!!! hahaha </TD></TR></TABLE>
one more reason a pair of mechanics gloves is the most often used tool in my tool box.
Old Jan 4, 2007 | 03:00 PM
tmrtwo's Avatar
forget about the block lets see a pic of ur girlfriend
Old Jan 5, 2007 | 01:44 PM
bluedlude's Avatar
well, i tried it yor way, and it didnt quit work out for me. my main problem was that i tried to take the bearing cap bridge off without removing the right side cover. once i got that off, i just slipped a 10mm box end wrench in this slot between the main caps and the bridge on the ends. then it came right up. from there it was pretty simple. thanks for the help.
xwhitchx
Jan 31, 2009 08:46 AM
JDM00SI
Nov 1, 2005 10:53 AM
T3mp3sT
Feb 23, 2005 03:02 PM
-iLLuZioN-B18C1
Aug 4, 2004 06:19 AM
Pengo
Jun 8, 2004 05:31 PM
