HID PROBLEM HELP!!!
Old Mar 23, 2007 | 02:32 PM
97ekcoupe's Avatar
Default HID PROBLEM HELP!!!
OK SO I BOUGHT AN HID KIT PLUG AND PLAY FROM A GUY ON TAMPA RACING.COM I SAW THEM IN THE CAR WORKING FINE NOW I GET HOME PLUG EVERYTHING UP AND THE DRIVER SIDE TURNS ON AND THEN GOES OUT I CALLED THE GUY HE SAID DIDNT HAVE THIS PROBLEM AND THEY WORKED FINE WHEN HE HAD THEM NOW IF I TURN THEM OFF AND TURN BACK ON ONCE OR TWICE IT STAYS ON ANY HELP THANKS!!!!!
Old Mar 23, 2007 | 03:25 PM
t0p_sh0tta's Avatar
Default Re: HID PROBLEM HELP!!! (97ekcoupe)
Does this happen with both lights? If not, switch ballasts, and see if the problem persists.
Check your grounds, and you power wires.
Old Mar 23, 2007 | 04:28 PM
BlueJdm's Avatar
you probably need a relay kit if it didn't come with one? Hid lights use alot of power when u first turn them on and if your not using a relay then it has to pull all the power from the stock harness and sometime the lights wont turn on because of it. a relay pulls power directly from the battery. I am having this same problem with a brand new kit i bought, and I jut got my relay kit today and I am going to be puttin it on tomorrow, I'll let ya know if it works for sure. I got my kit off ebay for like 20 bucks, it pretty high quality and the guy was very good to deal with...here is a link to the one that i bought, hope this helps
http://cgi.ebay.com/ebaymotors...ZWDVW
cridolph
Lighting
Jan 4, 2014 11:13 PM
Bizzle5OH3
Lighting
May 15, 2011 06:55 PM
xblind assassinx
Lighting
Aug 22, 2009 09:36 AM
stince
Lighting
Feb 22, 2008 02:32 PM
