wtf is wrong???
Old Mar 22, 2007 | 06:47 PM
ohsoslow's Avatar
Default wtf is wrong???
i gota 92 'lude si with a h23a1 the engine is fairly new. it has an idle problem and is leaking oil terribly. i know it is coming from under the intake sumwhere but i cant see exactly where. if anybody has had this problem of could have any idea wut it is and where its coming from ur help would be aprieciated. thanx
Old Mar 22, 2007 | 06:54 PM
saikou's Avatar
Default Re: wtf is wrong??? (ohsoslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsoslow &raquo;</TD></TR><TR><TD CLASS="quote">i gota 92 'lude si with a h23a1 the engine is fairly new. it has an idle problem and is leaking oil terribly. i know it is coming from under the intake sumwhere but i cant see exactly where. if anybody has had this problem of could have any idea wut it is and where its coming from ur help would be aprieciated. thanx</TD></TR></TABLE>
There is an abundance of information to be found on these forums. Chances are, if you have a problem, you'll be able to find an answer by using the search option.
Most likely, your oil leak is coming from the oil cooler o-ring that is behind the housing that your oil filter screws onto. Very, very common problem for these Preludes. Do a search and read up.
As for your idle problem; is the idle bouncing up and down?
Old Mar 22, 2007 | 07:01 PM
ohsoslow's Avatar
Default Re: wtf is wrong??? (saikou)
yeah the tach goes up and down and black smoke rolls out of the exhaust it looks like a diesel lol.
Old Mar 22, 2007 | 07:09 PM
BlownH23a
Guest
Posts: n/a
bouncing tach is fitv and/or iacv, i fixed both in my car problem solved, black smoke is you map sensor, check the vac lines, solved the problem in my car, oil leak is o-ring from oil cooler, 3.50 from honda takes 20 mins to fix including oil change.
Old Mar 22, 2007 | 07:14 PM
Boostedluder209's Avatar
what he said.
Old Mar 22, 2007 | 07:15 PM
ohsoslow's Avatar
Default Re: (BlownH23a)
thanks alot. but im not too sure about the oil leak tho.
EJcharlie
Jan 24, 2008 03:52 PM
Jonboy385
May 2, 2005 07:33 AM
civichtchback91
Jul 2, 2004 02:45 PM
WrongWheelDrive
Sep 18, 2003 10:43 PM
ckkl
Mar 25, 2002 04:43 PM
