h23 vtec spark plug problem....
Old Mar 27, 2007 | 01:52 PM
matbh22a's Avatar
Default h23 vtec spark plug problem....
Hi I've started my engine (h23 bottom-h22a head type-S pistons) engine runs good but spark plugs are strange.... running with p-13 stock for moment(break-in)
14 degree timing, and no 6 plugs....is that too hot plug ??? Should I get some colder ones??? thanks
Old Mar 27, 2007 | 02:17 PM
98vtec's Avatar
moderator emeritus
Default Re: h23 vtec spark plug problem.... (matbh22a)
tuning is essential to your break in. Thats all you need.
get rid of the stock ecu and get it done right.
Old Mar 27, 2007 | 03:20 PM
jdmlude5
Guest
Posts: n/a
yeah u r running really lean. dont drive it like that get it tuned
Old Mar 27, 2007 | 03:38 PM
PrecisionH23a's Avatar
Default Re: h23 vtec spark plug problem.... (jdmlude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">yeah u r running really lean. dont drive it like that get it tuned</TD></TR></TABLE>
Bingo.
Swapping plugs won't do anything for fueling.
Old Mar 27, 2007 | 03:53 PM
matbh22a's Avatar
Default Re: h23 vtec spark plug problem.... (PrecisionH23a)
yeah but when I first started it it was running a bit too rich and it ran a long time on idle .. So I tought it was beginning to clean up by itself. cause fuel pressure is at 40 psi on idle (vacuum not disconected) should I get it higher?? I dont want to get on dyno right now cause the engine is not really breaked-in. bottom and head is brand new.... thanks for your comments...
Old Mar 27, 2007 | 03:54 PM
Rich is better than lean. Regardless, you need to have it at least street tuned so you can drive around on it without leaning out or detonating.
What ems are you running? Injector size?
Old Mar 28, 2007 | 03:53 PM
matbh22a's Avatar
I'm running on a stock p-13 for the break-in procedures but will go on a tuned p-28. I've raised fuel pressure to 54 psi with vacuum disconected. Engine is not pinging and I'm not giving it a big load for now. but as I raise the fuel pressure, the idle seems to raise a bit. So should I continu to get it higher than that till my plugs gets around brown color??? thanks
Old Mar 28, 2007 | 03:59 PM
jdmlude5
Guest
Posts: n/a
well u need to look at your plugs again. it shouldnt be all grey like that. it should be black from the bottom to the bend at least.
Old Mar 28, 2007 | 06:39 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matbh22a &raquo;</TD></TR><TR><TD CLASS="quote">I'm running on a stock p-13 for the break-in procedures but will go on a tuned p-28. I've raised fuel pressure to 54 psi with vacuum disconected. Engine is not pinging and I'm not giving it a big load for now. but as I raise the fuel pressure, the idle seems to raise a bit. So should I continu to get it higher than that till my plugs gets around brown color??? thanks</TD></TR></TABLE>
stop driving your car.
tj0825
Mar 7, 2011 12:07 PM
radicalude
Feb 1, 2008 11:47 AM
preludeboybmw
Jan 28, 2008 04:03 PM
92LudeSI
Sep 10, 2003 05:02 PM
self_made
Oct 14, 2002 08:41 PM
