Broken VSS
Old Mar 22, 2007 | 11:21 AM
dominate9's Avatar
Default Broken VSS
My VSS stopped working one day. I pull it out, opened it up, and discovered that it has seized up. I bought a used VSS and swapped it in. It didn't work. I bought two other sensors and it didn't work. I'm guessing that there is something broken in the tranny? I don't know what gear in the tranny tha tthe gear on the VSS connects to. Help.
Old Mar 22, 2007 | 02:32 PM
nonvteclude's Avatar
Default Re: Broken VSS (dominate9)
the vss goes off the diff. if your speedo stopped working there is another speedo control box thats in the dash that could be out.
Old Mar 22, 2007 | 04:55 PM
Speedra500's Avatar
Default Re: Broken VSS (nonvteclude)
its probably something with your ecu or cluster, you could connect your vss wire to a multimeter and make sure it is sending output, pulsed 5v
Old Mar 23, 2007 | 12:12 PM
dominate9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">the vss goes off the diff. if your speedo stopped working there is another speedo control box thats in the dash that could be out. </TD></TR></TABLE>
I forgot to mention that it caused a CEL. So I don't think it could be anything with the cluster.
Old Mar 23, 2007 | 12:38 PM
i hate to ask but was the harness plugged in all the way? also was the vss itself all the way down on the housing?
Old Mar 23, 2007 | 04:18 PM
dominate9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">i hate to ask but was the harness plugged in all the way? also was the vss itself all the way down on the housing?</TD></TR></TABLE>
All the way down so that the mounting tab on the VSS was flush against the tranny. Harness plugged in tight.
joiv21
Aug 7, 2014 06:38 PM
ONEhaque
Oct 30, 2008 07:19 PM
Delano5050
May 5, 2007 08:52 AM
snackpack
Dec 18, 2006 02:39 PM
Bulldogg83
Aug 27, 2004 03:52 PM
