Service Plug?
Old Mar 24, 2007 | 08:14 AM
LukieLuc's Avatar
Default Service Plug?
Do i use the same service connector to check "check engine lights" as i use for checking the "ABS light" im trying to figure out how to check my abs light that keeps coming on, on the highway
Old Mar 24, 2007 | 08:22 AM
preylude's Avatar
Default Re: Service Plug? (LukieLuc)
The engine isn't coding because of the ABS light. That service plug isn't going to help you with that. Does the abs try to engage? Next time you see the light try hitting the brakes and see if they modulate. If not sounds like a light malfunction.
Old Mar 24, 2007 | 10:48 AM
LukieLuc's Avatar
Default Re: Service Plug? (preylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preylude &raquo;</TD></TR><TR><TD CLASS="quote">The engine isn't coding because of the ABS light. That service plug isn't going to help you with that. Does the abs try to engage? Next time you see the light try hitting the brakes and see if they modulate. If not sounds like a light malfunction. </TD></TR></TABLE>
no, you miss understood me, i want to read the ABS code i want to know how to? and the abs modulates between 20-40 mph it modulate for absolutly no reason, and then going at speeds above 60mph the light comes on, and when this happen i hear a clicking noise the more i speed up the faster the clicking gets, and when the abs disengages it stops
Old Mar 24, 2007 | 09:14 PM
cparreno's Avatar
It is the same connector, you really dont need 5 different post on the subject. https://honda-tech.com/zerothread?id=1931482
laurn
Suspension & Brakes
Feb 18, 2013 07:30 AM
prelude_93vtec
Apr 11, 2007 05:09 PM
TypeR0186
Dec 7, 2004 05:01 PM
oioioi
Oct 11, 2002 02:47 PM
