How do i check ABS code???
Old Mar 23, 2007 | 07:43 AM
LukieLuc's Avatar
Default How do i check ABS code???
The Abs light comes on only when im on the highway for like 5 min... going over 60, how will i be able to check that code?
Old Mar 23, 2007 | 08:52 AM
cparreno's Avatar
Default Re: How do i check ABS code??? (LukieLuc)
https://honda-tech.com/zerothread?id=1927329
Like I said in that post you have to short your service connector, if you dont know where that is, look behind your radio, there will be 2 connectors sitting on holders, it is the one with 2 wires to it, usually blue. Do this with the key off, then turn the key without turning the car on, and the abs light should start blinking. There is fast blinks and slow blinks, write them all down until they start repeating them selves. Post the code or get a manual and go from there. Good luck.
Old Mar 24, 2007 | 09:08 PM
cparreno's Avatar
I see you have 2 more post on this, do you still need help?
prelude_93vtec
Jun 28, 2007 02:58 PM
HOOKSH
Feb 11, 2005 05:55 AM
LudeinMD
Feb 10, 2005 08:52 AM
Havokgsr
Oct 1, 2002 03:25 PM
VTECAcuraGSR
Aug 18, 2002 03:33 PM
