compressor and radiator fan problems
Old Mar 21, 2007 | 03:32 PM
92spoonlude's Avatar
Default compressor and radiator fan problems
i am having a little problem with my compressor and radiator fan.. they won't work.. if anyone knows how to fix this problem please lmk...oh by the way the car doesn't overheat.. and i think this is making my ac not work...
Old Mar 21, 2007 | 03:35 PM
jdm_ekdc's Avatar
Default Re: compressor and radiator fan problems (92spoonlude)
hmmm. how many fans do you have? if you have 2. one is for ac and one is for cooling. the ac fan does turn on to cool the motor too but not as strong as the ac. turn on ur ac and see if the compressor and fan is kicking on. it could be a fan switch. let me know what happens wen u test everything out.
Old Mar 21, 2007 | 03:38 PM
Default Re: compressor and radiator fan problems (jdm_ekdc)
both of the fans do not work and when i turn on the ac from inside i don't hear the compressor kick on. i thought that it was because of the fan not turning on.. where is the fan switch?
Old Mar 21, 2007 | 04:10 PM
f22builder's Avatar
Check fuse # ?????
Check a fuse. I know certain componets will go out in tandem from the same fuse.
Old Mar 22, 2007 | 12:04 PM
Default Re: compressor and radiator fan problems (f22builder)
all the fuses that i know like the cooling fan fuse and the condensor fan fuse and they looks fine.
Old Mar 22, 2007 | 12:35 PM
MacONE's Avatar
the solders on ur climate control are prolly crack, those are known to do that. pm me and ill tell u wut to do.
Old Mar 22, 2007 | 12:43 PM
DfwBB6's Avatar
Default Re: compressor and radiator fan problems (MacONE)
what they said up top and if you cant follow the wires to see the culprit wire them direct!!!when u turn the ignition fans come on, now remember this means they will 4 ever stay on unless the car is turned completely off.
Old Mar 24, 2007 | 04:54 AM
yeah i tried doing that soldering thing and it seems to be the same. unless i did it wrong. i sew it from another site and tried to do it but since it was my first time i could of did it wrong. maybe. is there anyway of checking the motor of the fans?
Old Mar 31, 2007 | 03:29 PM
michael_kyoto's Avatar
Default Re: compressor and radiator fan problems (DfwBB6)
Hi,
I'm having problems with both compressor and the radiator fans. They don't turn on when I start up the vehicle. I've used the battery to run both fans, tried changing out the thermostat and a handful of other things per a Haynes manual. I've even traced the wires back to the fuse box and everything seems to be in working order with the exception of the previously noted fans. I'm thinking of looking at the solder connections in the climate control. Is there a particular type of solder recommend for the connections in this type of vehicle? Thanks and have a great day.
MK
ef8ftw
Sep 14, 2009 09:41 AM
duyfash0
Oct 8, 2008 06:46 PM
civicman69x
Jul 24, 2008 08:10 PM
Panda hatch
Jun 15, 2006 09:43 PM
