What function does a MAP sensor perform?
Old Mar 23, 2007 | 06:49 PM
JBirch_97Prelude's Avatar
Default What function does a MAP sensor perform?
My Prelude is having Idle problems. It was mentioned to me to change the MAP sensor, will this help?
Old Mar 23, 2007 | 06:54 PM
BlownH23a
Guest
Posts: n/a
changing the map sensor(if its bad) will only smooth the idle if your misfiring, not if its jumping up and down, that would be your fitv or iacv. MAP sensor tells the computer how much gas to inject per injector pulse by sensing the manifold vac. higher the vac the more load your car is under. so the injectors inject more gas and keeps your car from leaning out.
Old Mar 23, 2007 | 07:41 PM
Default Re: (BlownH23a)
Thank you, so I need a MAP sensor because my car has been Idling funny. It was not going up and but it was not was not maintaining Idle at operating temperature.
Old Mar 23, 2007 | 10:04 PM
98vtec's Avatar
moderator emeritus
Default Re: (JBirch_97Prelude)
the map sensor tells the ecu how much air is entering the throttle.
Old Mar 24, 2007 | 08:56 AM
Default Re: (98vtec)
My Prelude is just not idling once it gets to operating temperature and it throwing misfire codes.
Old Mar 24, 2007 | 09:14 AM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownH23a &raquo;</TD></TR><TR><TD CLASS="quote">changing the map sensor(if its bad) will only smooth the idle if your misfiring, not if its jumping up and down, that would be your fitv or iacv.</TD></TR></TABLE>
Old Mar 24, 2007 | 09:19 AM
THC07's Avatar
try some of these steps
http://www.ef-honda.com/ben/Badidle.php
Old Mar 24, 2007 | 10:37 AM
Default Re: (THC07)
THC07, thanks for the info, I will let you know how it goes!
Old Apr 18, 2007 | 07:22 AM
cody2689's Avatar
hi i know its an old post but i was wondering what the factory pressure is for an h22 i know its some number between 1 and 26. anybody got hte answer?
Old Apr 18, 2007 | 07:34 AM
Hawkze_2.3's Avatar
Default Re: (cody2689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cody2689 &raquo;</TD></TR><TR><TD CLASS="quote">hi i know its an old post but i was wondering what the factory pressure is for an h22 i know its some number between 1 and 26. anybody got hte answer?</TD></TR></TABLE>
Pressure for what? Fuel pressure, oil pressure, tire pressure....what?
Old Apr 18, 2007 | 08:13 AM
Speedra500's Avatar
Default Re: (Hawkze_2.3)
i think he was wanting headlight fluid pressure
Old Apr 18, 2007 | 08:17 AM
bluedlude's Avatar
i think hes asking what the difference in pressure between idle and full load is.....maybe?
Old Apr 18, 2007 | 08:20 AM
98vtec's Avatar
moderator emeritus
Default Re: (bluedlude)
idle you should see around 25-26" of vacuum, full throttle should be just under just above 0"
Old Apr 19, 2007 | 04:32 AM
THC07's Avatar
Don't be worried if it is at 20 or 22. most Honda's I've seen were.
and at WOT there is no vacuum
Old Apr 19, 2007 | 07:02 AM
cody2689's Avatar
Default Re: (THC07)
k thanks you i was wondering pressure at idle that helps. i just came to find out that my h22's map sensor was deleted and has a block off plate over it. could this be the reason my car is choppy as **** and is running richer than bill gates
Old Apr 19, 2007 | 09:56 AM
Hawkze_2.3's Avatar
Default Re: (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">
and at WOT there is no vacuum</TD></TR></TABLE>
Yeah, I'm at 22-24 at idle (on an H23 though).
Old Apr 19, 2007 | 12:00 PM
cody2689's Avatar
any suggestions about the map sensor delete could this be why my car is running so rich and choppy. i just recently installed an apexi neo... i was wondering if the tool will even work now that i think of it cuz doesnt the map sensor tell the injectors what to do
Old Apr 19, 2007 | 12:38 PM
kulrevon's Avatar
why do you have a map sensor delete?
Old Apr 19, 2007 | 07:43 PM
cody2689's Avatar
Default Re: (kulrevon)
exactly my point the recent owner must have done that
Old Apr 19, 2007 | 07:51 PM
cody2689's Avatar
wait where is the map sensor supposed to be located for an h22 93 prelude?
Old Apr 19, 2007 | 08:46 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cody2689 &raquo;</TD></TR><TR><TD CLASS="quote">wait where is the map sensor supposed to be located for an h22 93 prelude?
It could be on the firewall or on top of the throttle body. H-series have them both ways...
Old Apr 19, 2007 | 09:42 PM
BlownH23a
Guest
Posts: n/a
i have an extra firewall map sensor for sale, if you want it i could sell it to you for dirt cheap.
Old Apr 20, 2007 | 06:39 AM
cody2689's Avatar
k mine must be located on the firewall... is it in the box where the wiring for the egr come out of...the box also has a few vac line running to the intake manifold...i actually have a 1991 accord with an h22. still hopeing its on the firewall im pretty sure it is
Modified by cody2689 at 7:51 AM 4/20/2007
Nazraki
Feb 17, 2018 01:22 PM
zaks1
14
Dec 4, 2012 10:24 AM
civicEX1995
68
Jan 13, 2012 11:15 AM
Hella_Fresh
10
Apr 5, 2007 04:34 PM
Boostedb20EH2
Mar 5, 2007 06:41 PM
