subframe braces
Old Mar 22, 2007 | 07:34 PM
championshipwhite93si's Avatar
Default subframe braces
title says it.. ive searched a few times here and on another site and i cant find any info on anyone making any sub frame braces for the 4th gen lude. i have new sway bars and im looking for a little more ridgity. tower bars arent cracked up to be everything they are said so im looking for some good support. thanks guys
Old Mar 22, 2007 | 08:44 PM
Hawkze_2.3's Avatar
Default Re: subframe braces (championshipwhite93si)
Did you try google or ebay? There's tons of people making rear under braces and Tanabe makes a front under brace. There's also C-pillar bars.......but none of these bolt-in bars compare to a real roll cage.
Old Mar 22, 2007 | 09:08 PM
Default Re: subframe braces (Hawkze_2.3)
im looking for something along these lines.. i know its not a honda but it was the first thing i found with the bracing i want..
http://www.optionsauto.com/pro...13120
Old Mar 22, 2007 | 09:16 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by championshipwhite93si &raquo;</TD></TR><TR><TD CLASS="quote">im looking for something along these lines.. i know its not a honda but it was the first thing i found with the bracing i want..
http://www.optionsauto.com/pro...13120</TD></TR></TABLE>
They don't make anything like that. If you really want one, you'll have to make it, but anybody who actually tracks their car will tell you those bars don't do a whole lot.
Old Mar 22, 2007 | 09:17 PM
nonvteclude's Avatar
that would be custom on the lude. nobody makes them like that for our cars. one of the problems is you wouldnt have enough mounting points on the rear for that.
Old Mar 22, 2007 | 09:20 PM
Default Re: subframe braces (nonvteclude)
true.. i may look into these cusco bars i just found on options auto.
Old Mar 22, 2007 | 09:26 PM
you really do not need to spend that much money on them. $121 is crazy for that the tanabe's are just as good and they are $70. but like hawkz said they really arent that great, i have them seemed like they helped a little bit but honestly it was probably just me thinking they did.
Old Mar 22, 2007 | 09:29 PM
Hawkze_2.3's Avatar
Yep, I don't think the subframes are the first weakpoints to cause flexing....and even if they were flexing is not necessarily bad. Maybe get some stiffer bushings first...
Older Shelby Cobras were supposed to flex, and when people tried to stiffen them up they handled worse (I read too many magazines)
Old Mar 22, 2007 | 09:40 PM
i read alot too. lol. so you think a good bushing kit is the way to go first eh?
Old Mar 22, 2007 | 09:41 PM
what do you have for suspension so far
Old Mar 23, 2007 | 05:44 AM
tein basic damper setup with pillowball mounts and suspension technique adj. front and rear swaybar
Old Mar 23, 2007 | 05:57 AM
do some tower bars first they will do better than the subframes. you could do bushings they will help but its a hard install iff you dont have a press.
Hatch99
Suspension & Brakes
May 22, 2009 05:54 AM
MugenHonda
Dec 7, 2007 06:29 AM
Shingo
24
Sep 27, 2006 12:37 PM
nek9
17
Sep 23, 2006 04:50 PM
8point6
Jul 18, 2005 03:30 AM
