Nuts for the header
Old Mar 22, 2007 | 07:26 PM
GraphiteMW's Avatar
Default Nuts for the header
Quick question, just got my megan racing header.. ready to do the install tommorrow. What size nuts do I need for the top portion of the header where it bolts to the block. I want to replace my original ones because they are rusted to hell!
Old Mar 22, 2007 | 07:28 PM
manbearpig's Avatar
Default Re: Nuts for the header (GraphiteMW)
Dont know the size but you need to do a collector mod.
Old Mar 22, 2007 | 07:30 PM
GraphiteMW's Avatar
Default Re: Nuts for the header (joinerneal)
I plan on doing it when I get my custom kteller piping welded up!
Old Mar 22, 2007 | 09:40 PM
nonvteclude's Avatar
they are 12 mils. or are you talking about the studs
Old Mar 23, 2007 | 06:26 AM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW &raquo;</TD></TR><TR><TD CLASS="quote">Quick question, just got my megan racing header.. ready to do the install tommorrow. What size nuts do I need for the top portion of the header where it bolts to the block. I want to replace my original ones because they are rusted to hell! </TD></TR></TABLE>
if you took em off, then you should know...
they are 12 mm
Old Mar 23, 2007 | 07:36 AM
117's Avatar
117
The nut hex size is 12mm, but the bolt size is M8x1.25, IIRC. If you go to a store and ask for a 12mm nut, you're going to get something that's waaaay too big to work.
Old Mar 23, 2007 | 09:08 AM
GraphiteMW's Avatar
Default Re: Nuts for the header (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">if you took em off, then you should know...
they are 12 mm</TD></TR></TABLE>
Hmm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">The nut hex size is 12mm, but the bolt size is M8x1.25, IIRC. If you go to a store and ask for a 12mm nut, you're going to get something that's waaaay too big to work. </TD></TR></TABLE>
^ Exactly thanks, I've done it before by asking for a 10mm nut and getting something that didn't fit at all.
Old Mar 23, 2007 | 09:24 AM
InvaderTrax's Avatar
Make sure you get the same kind of nut that's on there now. Don't just get a regular 12mm nut. And to remove them, get the car nice and hot, and hold the back end of a candle to each stud. It'll suck the wax in and make it 100x easier to break them loose tomorrow
Old Mar 23, 2007 | 10:44 AM
.BigSexy's Avatar
most hood white kid
Hmm
well...you took them off, so just take one to a hardware store, or auto parts store, and say, I need 10 just like these. Problem solved
Old Mar 23, 2007 | 02:54 PM
GraphiteMW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">well...you took them off, so just take one to a hardware store, or auto parts store, and say, I need 10 just like these. Problem solved</TD></TR></TABLE>
The car that I am putting the header on is the only mode of transportation I have. I don't think that'd work out so great.
Anyways, I went to install it and couldn't get the down pipe to unbolt from the cat because the bolts are rusted to hell. I'm just gonna take it to the shop to get it installed.
Old Mar 23, 2007 | 04:43 PM
I was lucky enough to have access to a lift when I installed mine, so I was able to get the bolts on my cat off. It's near impossible to do on your back
Old Mar 23, 2007 | 04:58 PM
93sivtec's Avatar
Ha ha yeah I did it on my back....and it was rough,busted my knuckles in the process,but in the end &gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt; I prevailed.
Old Mar 23, 2007 | 07:45 PM
GraphiteMW's Avatar
Default Re: (InvaderTrax)
Yeah I couldn't get at it at the right angle.. wasn't even to fit my cheater bar under the car so I can break loose the nuts. I was disappointed.
Dahl Sol
Nov 30, 2009 01:51 PM
Amused
Aug 23, 2006 05:34 AM
Train
Mar 13, 2004 04:35 PM
H22ek4
Jul 8, 2003 03:45 PM
