ebrake conversion
Old Mar 22, 2007 | 09:46 PM
pprowler6's Avatar
Default ebrake conversion
alright guys ive searched and read the results but the wirteups have seemed to dissappear over the years anyone have one to convert to the 94+ ebrake console thing from a 92 93 lude?
Old Mar 22, 2007 | 10:23 PM
x01vtec's Avatar
Default Re: ebrake conversion (pprowler6)
yes.
parts list:
console
cupholder (thats why youre doing this right? we should dub this the cupholder mod instead of pussyfooting around the issue at hand)
ebrake
parking cables*
tunnel cover*
* = optional
the earlier 4th gens have shorter parking brake cables, swapping cables is the oem replacement way as is replacing the sheet metal frame that gives the hardware for the center console and such to connect to the tunnel. swapping the metal frame over the tunnel is the cleanest way to do it and everything will line up perfectly and the ebrake will work the same way by swapping in the 94+ cables.
* is optional because... you can fab up a sort of extension to the existing cables to the parking lever. you can also fab up a way to mount the lever itself, you will have to move its mounting hole locations to mount the lever for the new console.
i do not have pictures of either way. i did the swap on my 92 but i swapped the metal tunnel cover. others have fab'd up ways to make it work without drilling spot welds and welding but i tend to overdo things even if you will never see them.
Old Mar 23, 2007 | 04:49 AM
coldfission's Avatar
Default Re: ebrake conversion (x01vtec)
i would like to see pics of this.
Does the carpet continue under the huge console in the back seat?
Old Mar 23, 2007 | 08:14 AM
jdmlude5
Guest
Posts: n/a
Default Re: ebrake conversion (coldfission)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coldfission &raquo;</TD></TR><TR><TD CLASS="quote">i would like to see pics of this.
Does the carpet continue under the huge console in the back seat?</TD></TR></TABLE>
no u gotta get the center piece for the back seat. its 2 pieces.
Old Mar 23, 2007 | 10:35 AM
M2B4's Avatar
Default Re: ebrake conversion (jdmlude5)
im in the process of doing this my self. ive got it planned out just havta find time to do it. IMO its just time consuming not that difficult.
LobeSex
Apr 6, 2009 12:46 PM
Tacoma Luda
Aug 8, 2007 11:30 PM
LaEzEnT
Sep 23, 2005 09:26 AM
mhgleitz
Mar 6, 2004 08:03 PM
