Help, Problem with Tps!
Old Apr 15, 2007 | 04:28 PM
JasonST's Avatar
Default Help, Problem with Tps!
So I finally had some time to diagnose my stupid tps problem that I've had for awhile. The problem is that frequently when I'm driving the tps light will go on, I constantly check the tps and the voltage at idle is dead on .5V and WOT 4.5V. Today I checked the connectivity and resistance of all the tps wires and they're fine. So then I played around with the gas pedal while I checked the voltage. It would bounce up to 4.5v like it's suppose to but after a couple times it would go up to .55V for idle, then to .6V, and .6v, like something inside the tps was broken. I think this is what's causing my tps problem, because I only have the problem at idle, the car will jerk when I'm in gear but giving it no gas, and at idle sometimes it will idle quite high. So would getting a new TPS likely fix the problem or does someone think the problem lies elsewhere? Any beneficial help is welcomed.
Old Apr 16, 2007 | 09:35 AM
JasonST's Avatar
Default Re: Help, Problem with Tps! (JasonST)
bump. cmon anyone with a halfway descent answer?
Old Apr 16, 2007 | 10:32 AM
nonvteclude's Avatar
it sounds like the tps failed to me. if you can use one from a buddies car and see if that helps before you by one
Old Apr 16, 2007 | 10:46 AM
Hawkze_2.3's Avatar
I would say get a new TPS from ebay or something...
Old Apr 16, 2007 | 07:15 PM
94vtirozguy's Avatar
when i had tps issue. I took it off and foudn the spring inside rests on a plastic piece. That could be worn, or even worse broken.
Old Apr 17, 2007 | 07:13 AM
JasonST's Avatar
Default Re: (94vtirozguy)
Ok, thanks for the replies everyone. Guess I will have to get a new one. I'll keep you posted.
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
alupso
17
Apr 18, 2006 07:21 PM
andysila
Apr 4, 2006 06:46 AM
matt j
Jan 2, 2004 07:21 AM
