Using base LCA on SH
Old Apr 15, 2007 | 12:25 AM
lude98SH's Avatar
Default Using base LCA on SH
My question is , is it possible to run a base LCA (in order to run a traction bar system) on an SH ? Does it bolt to the knuckle differently ? Would i have to change the knuckle also ? Anyone have any ideas ?
Old Apr 15, 2007 | 03:03 PM
lude98SH's Avatar
Default Re: Using base LCA on SH (lude98SH)
bump
Old Apr 15, 2007 | 04:23 PM
mafia's Avatar
sorry to ask but what is a LCA?
Old Apr 15, 2007 | 04:28 PM
vinuneuro's Avatar
Default Re: Using base LCA on SH (mafia)
LCA= lower control arm. You can't use the base lca because in the sh suspension, the sway-bar endlink connects to the lca. The only to accomplish what you're trying to would be to replace the entire front suspension, including the subframe.
Old Apr 15, 2007 | 05:51 PM
lude98SH's Avatar
Default Re: Using base LCA on SH (vinuneuro)
damm thats a bitch. Has anyone fabbed anything up to be able to use a traction bar ?
.Gen2gsr.
Suspension & Brakes
Dec 12, 2013 05:28 PM
5.0 Killa
Jan 18, 2009 08:50 AM
krkline2gdsm
Suspension & Brakes
Oct 26, 2007 05:25 AM
hon da top
Dec 18, 2005 08:37 AM
Dan GSR
Aug 23, 2002 08:06 PM
