F22 Header
Old Apr 11, 2007 | 06:24 PM
cfran55's Avatar
Default F22 Header
hey guys i searched and everything but im still confused about getting a header for my f22
my question is that i know h23 fits but what modifications would i have to do besides extending the o2 sensor. When i was searching i found a thread that said something with the downpipe needed to be modified.
So people with a f22 header could you post pics/explain what you did
Old Apr 12, 2007 | 05:03 PM
cfran55's Avatar
Default Re: F22 Header (cfran55)
bump anyone know??
Old Apr 12, 2007 | 06:41 PM
pinecone's Avatar
I am confused about what you want to do here. Are you trying to use an F22 or H23 header or a mix match system? Is it going on a F22 or H23? Why not just buy a header for that motor?
Old Apr 12, 2007 | 07:48 PM
cfran55's Avatar
Default Re: F22 Header (pinecone)
its for an f22
i can not find a f22 header except for those for accords
so i searched here and people said megan h23 header. Now im wondering is it just a direct bolt on besides the fact that you have to extend the 02 sensor
so if anyone with an f22 what header do you have i was thinking about purchasing one on ebay
Old Apr 12, 2007 | 08:17 PM
pinecone's Avatar
I have an F22 megan header.
Old Apr 13, 2007 | 05:04 AM
cfran55's Avatar
on their website they only have
Honda Prelude 92-96 Si
Honda Prelude 92-96 Vtec
So im thinking to get the prelude si one. Will that be a direct fit?
Old Apr 13, 2007 | 05:30 AM
cpmike's Avatar
is your o2 sensor on the header at the top, or on the downpipe behind the block? the megan headers have the o2 down behind the block, so you may or may not have to extend wires, but thats simple.
either way, an H23 header for an Si or an F22 header for an accord would be a direct bolt on and fit perfectly.
Old Apr 13, 2007 | 05:40 AM
cfran55's Avatar
Default Re: F22 Header (cpmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpmike &raquo;</TD></TR><TR><TD CLASS="quote">is your o2 sensor on the header at the top, or on the downpipe behind the block? the megan headers have the o2 down behind the block, so you may or may not have to extend wires, but thats simple.
either way, an H23 header for an Si or an F22 header for an accord would be a direct bolt on and fit perfectly.</TD></TR></TABLE>
yea its at the top so i will have to extend it
alright thanks for your clear answer
ill be ordering the h23 one soon
Old Apr 13, 2007 | 06:32 AM
pinecone's Avatar
It should be. People only have problems it sounds like when they try to put a h22 header in their car that originally had an h23 in it and the original exhaust.
My o2 sensor hole is on the header, not on the downpipe.
Old Apr 13, 2007 | 06:50 PM
cfran55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">It should be. People only have problems it sounds like when they try to put a h22 header in their car that originally had an h23 in it and the original exhaust.
My o2 sensor hole is on the header, not on the downpipe.</TD></TR></TABLE>
what kind of header did you get?
Old Apr 14, 2007 | 02:52 PM
jzobie1's Avatar
H22 and F22 share a header. The H23 head has a different exhaust port setup but with the help of a drill you can get a DSM turbo manifold to fit the H23. Get the H22 header and enjoy the neck snapping power.
Old Apr 14, 2007 | 04:12 PM
cfran55's Avatar
Default Re: F22 Header (jzobie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jzobie1 &raquo;</TD></TR><TR><TD CLASS="quote">H22 and F22 share a header. The H23 head has a different exhaust port setup but with the help of a drill you can get a DSM turbo manifold to fit the H23. Get the H22 header and enjoy the neck snapping power.</TD></TR></TABLE>
are you sure about the h22 and f22 i always thought h23 and f22 shared the same ports and boost is on my mind but is not an option for a couple years
Old Apr 14, 2007 | 05:05 PM
pinecone's Avatar
Nope. I know the H22 header is nowhere close to either the H23 or the F22 exhaust ports. Now I don't recall if the H23 and F22 are close enough to be swappable, they might be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">I have an F22 megan header. </TD></TR></TABLE>
To answer your question about what header I have.
Old Apr 14, 2007 | 05:17 PM
cfran55's Avatar
f22 for an accord? if so what years
Old Apr 14, 2007 | 07:23 PM
pinecone's Avatar
No the F22 in the Prelude, 92-96. F22a1. I am not sure if the accord headers are the correct length.
Old Apr 14, 2007 | 08:36 PM
cfran55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">No the F22 in the Prelude, 92-96. F22a1. I am not sure if the accord headers are the correct length.</TD></TR></TABLE>
how did you find a f22a1 header the only prelude header i see say si or vtec
Old Apr 14, 2007 | 11:28 PM
jzobie1's Avatar
Well Ill tell you that I have an H23 in my Prelude and an F22 in my accord. I bought a DC header before I had my Prelude and ordered an H22 header that fits fine. When my H23 needed a header I looked at the accord to use its header but they are completely different. I am assuming that you are talking about the F22a motor that came in your Prelude S model. If that is the case then the F22a header is the same as the H22 header, look at the diagrams in the middle of this page. The H23 and F22b exhaust ports are siamesed and the H22 and F22a are not.
https://honda-tech.com/zerothread?id=1579389
Old Apr 15, 2007 | 06:25 AM
pinecone's Avatar
Did you even look at the exhaust ports?
F22a1- 0-0-0-0
H22a- 0-00-0
F22b- 0-00-0
The H22a1 and f22a1 exhaust ports are not close in the least. It will line up with the F22b series motors alot closer than with the F22a series.
Old Apr 15, 2007 | 06:51 PM
Jacen's Avatar
Ok sorry to hijack the thread but I also have a question. I have a 93 Prelude S (F22A1) what header should I buy that will fit, since ebay only sells SI and H22 headers? Also is the catbacks all the same for 92-96 preludes?
Old Apr 15, 2007 | 07:40 PM
cfran55's Avatar
Default Re: F22 Header (Jacen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jacen &raquo;</TD></TR><TR><TD CLASS="quote">Ok sorry to hijack the thread but I also have a question. I have a 93 Prelude S (F22A1) what header should I buy that will fit, since ebay only sells SI and H22 headers? Also is the catbacks all the same for 92-96 preludes?</TD></TR></TABLE>
not really a hijack except for the catback part but the first question is also what im looking to find out
Old Apr 15, 2007 | 08:17 PM
pinecone's Avatar
The catbacks should be the same. The only real difference is the exhaust ports and that the h22 header is a different length than the other 2.
Mishako129
Feb 12, 2014 01:26 AM
Dabrybry
Oct 25, 2008 01:16 PM
All-Motor-Junkie
Mar 12, 2008 07:45 PM
AlexLude
Jul 27, 2005 09:25 PM
Yuleluder
May 15, 2003 08:59 AM
