Another VTEC question
Old Apr 14, 2007 | 12:33 AM
lazyhenry30's Avatar
Default Another VTEC question
Hi,
I just got this 98 Prelude and i dont think my VTEC is kicking in. I have driven the car up to 6,000 RPM in both 2nd and 3rd gear, but i dont feel this kick everyone tells me about. Am i suppose to be flooring the car when i am trying to hit VTEC?
Also, i found this one site where you can run your VIN number and it will tell you if your car has been serviced for the recalls. I can't find this site anymore. Anyone know of the site that i just mention?
thanks.
Old Apr 14, 2007 | 01:01 AM
thegeorge613's Avatar
Default Re: Another VTEC question (lazyhenry30)
Check your oil level, then check your VTEC solenoid. If your oil level's low, VTEC won't engage.
As for the website, I think it's this one: https://www.ahm-ownerlink.com/...2Easp
Old Apr 14, 2007 | 06:46 AM
jdmlude5
Guest
Posts: n/a
well its an obd2 car. so if vtec was not kicking in because of low oil it would throw a cel. but yeah floor it,,,
Old Apr 14, 2007 | 08:48 AM
Prudz_lude's Avatar
Default Re: Another VTEC question (jdmlude5)
whats a 93 h22a1 original motor? obd2 or obd1?
also i would suggest checking the oil level as well. i had the same problem, oil just got burned fast because i was vtecing to much lol
Old Apr 14, 2007 | 09:19 AM
jdmlude5
Guest
Posts: n/a
Default Re: Another VTEC question (Prudz_lude)
a1 is obd1. his is obd2.
Old Apr 14, 2007 | 09:23 AM
Prudz_lude's Avatar
thanks.
Old Apr 14, 2007 | 09:46 AM
93 H22?, what do you mean by that. LOL, as you can tell i dont know much about cars.
Anyways, where can i check the oil level for VTEC? If your talking about engine oil, then i have more than enough, i just got an oil change on it. IF possible a picture would be a lot easier for me to locate the VTEC oil. Also where is the solenoid you guys are talking about?
And THANK YOU
thegeorge613, that is the exact website i am talking about
Old Apr 14, 2007 | 10:17 AM
98savage's Avatar
There is no "VTEC oil"....it is just the oil you put in your car. If the oil pressure in your block is too low, VTEC will not engage. But they also said that if you had low oil pressure, you will have the check engine light on. Which I am assuming you don't have on. So nothing to worry about there.
Also, you don't always feel VTEC...it engages ALL THE TIME but if you feel anything, that's torque carrying you through the band. I'm sure the VTEC works on your car though....
Old Apr 14, 2007 | 11:26 AM
Prudz_lude's Avatar
Default Re: Another VTEC question (98savage)
93 is the first year h22s were introduced in the prelude. its pretty rare to find a original h22 in a 93 that has never been rebuilt.
Old Apr 14, 2007 | 12:32 PM
oo ok, i will have to see if VTEC kicks in later on today. My car is in the shop right now getting the inner axle fix, value leak, distributor leak, and steam clean the engine.
Thanks guys,
This forum is really great. it doesn't take long for someone to reply back to a topic
Old Apr 14, 2007 | 03:53 PM
xthekidx's Avatar
you should be able to feel it or hear it. my **** is loud as expletive when it engages with just headers and 2.5" down pipe
Old Apr 15, 2007 | 07:26 AM
rudelude79's Avatar
ran into the same problem on my vtec lude it was the wire going to the sol. fell out of the plug
Old Apr 15, 2007 | 03:03 PM
street_ride14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude &raquo;</TD></TR><TR><TD CLASS="quote">93 is the first year h22s were introduced in the prelude. its pretty rare to find a original h22 in a 93 that has never been rebuilt. </TD></TR></TABLE>
I got one.
Old Apr 15, 2007 | 04:39 PM
ilikehonda's Avatar
ah hahahahahahahaha.....where did you get that info
Old Apr 15, 2007 | 04:51 PM
Hawkze_2.3's Avatar
Default Re: Another VTEC question (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">
ah hahahahahahahaha.....where did you get that info</TD></TR></TABLE>
In the USA we didn't get the H22 until 93. Only Prelude SI's and S's in 92.
Old Apr 15, 2007 | 05:46 PM
manbearpig's Avatar
Default Re: Another VTEC question (Hawkze_2.3)
I think he was referring to the fact that few have never been rebuilt. I have a 94 that's never been rebuilt, aside from replaced valves.
Old Apr 15, 2007 | 09:47 PM
Inextricabledrvr's Avatar
Yes you are suppose to be "flooring it" to engage in VTEC.
Old Apr 16, 2007 | 09:14 AM
ilikehonda's Avatar
mash that bitch to get vtec
Old Apr 16, 2007 | 09:34 AM
idrivealude's Avatar
yeah if u dont have it atleast 3/4 floored vtec wont engage, also if the engine is still cold, meaning u havent warmed it enough long enough it will only rev up to 5k.
Old Apr 16, 2007 | 09:39 AM
JasonST's Avatar
Default Re: Another VTEC question (idrivealude)
I got a 93 jdm h22a. Never been rebuilt, works great, even has original timing belt, which i need to replace sometime. Anyways, are u throwing a check engine light? If u're not then it should be working.
Old Apr 16, 2007 | 12:17 PM
canman44's Avatar
Default Re: Another VTEC question (JasonST)
Yeah my friends vtec on his del sol is pretty loud. It actually sounds like its the engine is knocking. At whatever rpm its set the vtec kicks in and you can definitely tell.
Old Apr 16, 2007 | 06:33 PM
cool, since this is my second car i am babying the car and i haven't even began to race it out, i have only pressed the gas less than half way down.
But for normal driving, how hot does your car get? In normal driving, i can smell like burnt oil faintly, but the heat that is emitting from the engine is way strong. How does are your lude?
and no, my check engine is not on
Old Apr 16, 2007 | 10:28 PM
Default Re: (lazyhenry30)
finally hit VTEC tonight!!!!!
blacktibby07
May 14, 2011 11:12 AM
flowmaniacscrew
18
Aug 2, 2009 02:32 PM
sosalka
Dec 9, 2007 10:52 AM
TheAccordGuy
Dec 27, 2006 07:51 AM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
