Prelude LSD ???
Old Apr 11, 2007 | 02:57 PM
prelude1911's Avatar
Default Prelude LSD ???
Can I install a quaife LSD in my 1997 Honda Prelude SH? I am going to remove the ATTS unit. I was wondering what the difference between the SH tranny and the base.
Old Apr 11, 2007 | 03:20 PM
kulrevon's Avatar
Default Re: Prelude LSD ??? (prelude1911)
I am not sure. From the SH to the base the case, the differential, the counter shaft, and one of the differential bearings(one closest to engine) are different. Everything else is the same including main shafts, gears, shift forks.
The case of course is going to be different because of the mounting of the atts. the question is if the counter shafts are different diameters or can you interchage them. I would have the SH differential and compare it to a base or an lsd.
Just remember you are going to need an adapter plate for a base half shaft on the sh engine.
Old Apr 11, 2007 | 03:28 PM
Default Re: Prelude LSD ??? (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">I am not sure. From the SH to the base the case, the differential, the counter shaft, and one of the differential bearings(one closest to engine) are different. Everything else is the same including main shafts, gears, shift forks.
Just remember you are going to need an adapter plate for a base half shaft on the sh engine. </TD></TR></TABLE>
Yeah, i know i need to make a custom plate to hold the intermediate shaft. I just need to know if the LSD will fit in it. Has anyone every try this?
Old Apr 11, 2007 | 04:13 PM
Silver Surfer's Avatar
what is the point of having the SH without atts?
sell your SH and get a Base and use the profit to pay for the lsd
Old Apr 11, 2007 | 09:19 PM
P13_mein's Avatar
why would u replace an active differential with a 1 or 1.5 way?
unless you're planning some big boost
Old Apr 11, 2007 | 09:29 PM
Mykizism's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1911 &raquo;</TD></TR><TR><TD CLASS="quote">Can I install a quaife LSD in my 1997 Honda Prelude SH? I am going to remove the ATTS unit. </TD></TR></TABLE>
no
Old Apr 12, 2007 | 04:54 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1911 &raquo;</TD></TR><TR><TD CLASS="quote">Can I install a quaife LSD in my 1997 Honda Prelude SH? I am going to remove the ATTS unit. I was wondering what the difference between the SH tranny and the base.
no x2
Old Apr 12, 2007 | 04:57 AM
godslayer's Avatar
Default Re: Prelude LSD ??? (Silver Surfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer &raquo;</TD></TR><TR><TD CLASS="quote">what is the point of having the SH without atts?
sell your SH and get a Base and use the profit to pay for the lsd</TD></TR></TABLE>
Why would you sell the car, most likely at a loss, buy another nearly identical car, at an inflated price and of unknown reliablility, if he may be able to do what he wants to do, for whatever reason, with what he has?
Old Apr 12, 2007 | 08:19 AM
mgags7's Avatar
Default Re: Prelude LSD ??? (P13_mein)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein &raquo;</TD></TR><TR><TD CLASS="quote">why would u replace an active differential with a 1 or 1.5 way?
unless you're planning some big boost</TD></TR></TABLE>
dude put gran turismo down
Old Apr 12, 2007 | 08:40 AM
ProjectBB6's Avatar
Default Re: Prelude LSD ??? (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
dude put gran turismo down</TD></TR></TABLE>
Lol... x2
Old Apr 13, 2007 | 07:42 AM
alright so it won't work. thanks. just talk to gearspeed and they also said the lsd wont fit in the sh tranny. so im just going go with a 1992-96 tranny or a 1997-01 base tranny and put an aftermarket lsd in it. another questions though, how difficult is it to put the lsd in?
Old Apr 13, 2007 | 10:27 AM
577HondaPrelude's Avatar
Default Re: (prelude1911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">another questions though, how difficult is it to put the lsd in? </TD></TR></TABLE>
if you can get the tranny out, cracking the case and stalling the LSD will not be that hard. The Prelude shop manual (the one you get from HelmINC) has step by step instructions that you can follow.
Basic rundown (if I remember right):
remove axle nuts while car is on ground, then jack it up as high as you can
remove wheels,
remove LCA from knuckle (use Pittman arm puller)
remove radius rods,
disconnect bottom of shocks from LCA
remove front lower cross-member (the one that has the front motor mount on it)
remove intake up to the throttle body
remove battery and battery tray
remove starter
remove clutch slave cylinder (leave lines connected)
remove clutch dampener (leave lines connected)
disconnect reverse gear sensor, and VSS sensor wires
remove any wire holders that blot to the tranny
disconnect shift cables, and shift cable brackets
remove engine stiffener plate from tranny/oilpan
drain tranny oil
remove axles and half shaft
support tranny with a jack
support engine with a jack or jack stand under the oil pan with a big block of wood
remove all tranny to engine bolts
remove right side, and rear engine mounts (they both connect to the tranny)
lower tranny, and wiggle it lose from the clutch.
Old Apr 13, 2007 | 11:38 AM
i meant cracking the case open and installing the lsd into the tranny. thanks for the info anyways!
Old Apr 13, 2007 | 12:24 PM
P13_mein's Avatar
Default Re: Prelude LSD ??? ()
Quote, originally posted by mgags7 »
dude, those are simple things,
go get a kia then
Old Apr 13, 2007 | 01:17 PM
nikolai.'s Avatar
its not too hard to get the case open and get the new lsd in.
you are going to need either a vise or an impact wrench to get the final drive gear bolts on and off the diff (they are left hand thread btw) and prolly a torch of some sort to heat the vss gear till you can pull it off the diff.
i would buy new bearings for the diff as well as new oil seals, thrust washers and ALL of the diff thrust shims. you will only use one of them, but you could spend months waiting for new ones to come in when you realize the ones you bought didnt work. a cheap seal driver kit from harbor freight will come in handy as well.
you are also going to need a torque wrench that can measure 12-24 INCH pounds and some way to spin the differential with the torque wrench. if you can fit a length of threaded rod through the diff (not sure if quaiffe can do this) then you can jam some washers on either end to spin it, otherwise you'll need to cut a spare axle and weld a socket onto it.
don't try this without a Helm's.
Prelude Type O
Jun 5, 2018 08:55 PM
uleiro
May 19, 2008 05:58 PM
rsSEX
Oct 4, 2006 11:10 AM
Understeer
May 10, 2005 10:43 AM
Lude454
Apr 2, 2005 04:32 PM
