Wrong Rims Offset
Old Apr 9, 2007 | 06:10 PM
RickyJa's Avatar
Default Wrong Rims Offset
Hey y'all, I hope someone may help me with the situation.
I recently bought some ADR Mach 8 rims for my 97 SH which is lowered. The person that I bought them from took them off his 99 Base Lude, also lowered. After I put the rims on I realized that the rear wheels were touching when making sharp corners and when exessive load hits the back.
The wheel specs are as follows;
17x7 40mm
I have 17/205/40ZR tires on.
Has anyone ever taken their rims to a machine shop to modify the rims because of the wrong offset?
I was just curious to see if a machinist can take off a few fraction of an inch to make them fit my Lude.
If that cannot work I may just have to try and sell or swap them.
Old Apr 9, 2007 | 07:16 PM
InvaderTrax's Avatar
This is something I had thought of incase the time came. It would be much better for you to bring the rotors to the shop and have them take 2mm off the hat than to machine the rim itself. Also, it's cheaper to replace a rotor over a rim
Old Apr 9, 2007 | 07:19 PM
Sakanora's Avatar
it's also less stressful to just have your rear fenders rolled, this will increase the rear fender clearence by another .5 cm
Old Apr 9, 2007 | 07:24 PM
Prelude_2_NV's Avatar
Default Re: (Sakanora)
It might actually be just rubbing the rear bumper tab.
Old Apr 10, 2007 | 06:50 AM
RickyJa's Avatar
Default Re: (Prelude_2_NV)
Would I be able to roll the fenders myself or would I have to take it to a shop?
Old Apr 10, 2007 | 07:27 AM
sigmiester's Avatar
Default Re: (RickyJa)
techincally u could do it with a baseball bat or any other round object and roll it around the wheel until the inside is flush with the fender. personally though i would take it to a shop, it shouldnt cost very much to have them do it and then u dont have to worry about it.
Old Apr 10, 2007 | 09:07 AM
professorman's Avatar
Default Re: (sigmiester)
Ask on VAdriven.com to see if anyone in NoVA have a fender roller for rental/loaner
Old Apr 10, 2007 | 11:26 AM
RickyJa's Avatar
Default Re: (profroopchan)
Will check on the fender roller.
Old Apr 10, 2007 | 08:29 PM
Phone books FTW. So much more gentle vs a baseball bat
cf5412
Honda CR-V & Element
Nov 10, 2016 03:00 PM
low_and_slow
Apr 25, 2010 08:51 AM
strtracedrmr
Honda Civic (2001 - 2005)
Sep 9, 2007 05:33 PM
RickyJa
Apr 22, 2007 06:47 AM
