Head Light Problems ?? Please help.
Old Apr 6, 2007 | 10:08 PM
tadcostin's Avatar
Default Head Light Problems ?? Please help.
I just bought a 94 lude with h22 engine. When headlight in low beam, the right low beam is excessive intense and the left is barley lit. Both high beams are barely lit. When turn on high beam switch, both right lights are extremely intense and both left side lights go off... ?? relay, bad wiring, any ideas???
Old Apr 7, 2007 | 07:45 AM
GraphiteMW's Avatar
Default Re: Head Light Problems ?? Please help. (tadcostin)
Check the grounds on the left side, along with the wiring and relays.
Old Apr 7, 2007 | 11:39 AM
tadcostin's Avatar
Default Re: Head Light Problems ?? Please help. (GraphiteMW)
OK, figured out where the problem is after blowing a couple of fuses, the car has the projector type head assemblies, there is a short some where in the low beam wiring on one of them.. So I am trying to decide if I want to take apart the whole light assemblies, ( i assume I have to take off front bumper due to the way these are in there, arrgg). Or, just modify the casing and attach self wired lamps in them. Which is probably the way i am going. Thanks for the response..
NoMechanic
Mar 24, 2013 01:27 PM
Turbolude96
Nov 21, 2012 07:59 PM
d16man
Jan 10, 2010 05:08 PM
gqstatus05
Sep 17, 2008 08:16 AM
jaycetan
Apr 2, 2005 08:47 AM
