Weird shaking problem when accelerationg around 3500 RPM
its pretty weird....if im in 5th gear...and i put the pedal to the floor (WOT) at 3k rpm to about 4500 -5000 rpm...i can feel some sorte of shaking like if it was comming from the wheels or something....
its like if it was the engine...and what i was worried is maybe my balancer shaft belt broke?...anyone else ever have this problem? thanks
Re: Weird shaking problem when accelerationg around 3500 RPM (teg969)
just got tire repair by who? maybe take it back and tell them to ballance all 4 tires again (you might have to pay for other tire balancing)
Only at WOT? Can you make it happen at the same speeds in 4th gear (or maybe 3rd)?
Could be an Axle (CV Joint). Or loose lug nuts.
I would guess wheel/tire first. You could rotate the wheels front/rear to check if the vibration moves.
