2 problems..i need some advice
Old Apr 16, 2007 | 01:41 PM
smokedyou19's Avatar
Default 2 problems..i need some advice
First: is i put my oem power steering pulley and alternater pully back on but now they squeek everytime i first start up the car and sometimes while i drive. If i put more power steerign fluid in would that help?
Second: Gas pedal sticking. now i did some research and people have said that if you fool around with the throttle body this could have an effect. Meaning trying to keep the throttle body open longer so the bigger cams can run properly. Any adive with that would be great.
Thanks
Steve
Old Apr 16, 2007 | 01:45 PM
nbimprtlude20's Avatar
Default Re: 2 problems..i need some advice (smokedyou19)
r u sure the belt is on tight enough and not slipping?
Old Apr 16, 2007 | 02:17 PM
Default Re: 2 problems..i need some advice (nbimprtlude20)
Im pretty sure there on tight enough i mena i had a shop do put them on could it be because they havent been on the car in a while or smething
Do you know anyhting about hte gas pedal sticking im pretty sure its what i said but im not sure how to fix it do i tighten the cable or loosen it
Old Apr 16, 2007 | 02:36 PM
slammed95lude's Avatar
If the pedal is sticking check the spring also get some white lithium grease and spray it on all moving parts on the pedal but not the sensors. As for your belts check the tension you should be albe to move them with your finger a quarter of an inch
85crx509
Sep 3, 2008 11:10 AM
mr poo
15
Jun 14, 2006 08:09 PM
TheThiefTheKnife'NTheGun
Nov 1, 2005 03:46 AM
HipHop Junkie
11
Mar 10, 2005 11:23 PM
Ideal
Nov 1, 2002 07:17 PM
