HID problem
Old Apr 16, 2007 | 07:16 PM
Inextricabledrvr's Avatar
Default HID problem
I have a set of Mccolluch HID's on my 97 SH and when I installed them the passenger light would flicker on and off constantly.
The drivers side was fine, but I don't get why the passenger would be doing this?
Bad bulb? wiring? ballasts bad?
Anybody experience any problems with their plug and play HID kits?
Thanks
Old Apr 16, 2007 | 07:20 PM
prelude1897's Avatar
Default Re: HID problem (Inextricabledrvr)
usually if you have a problem with your HIDs flickering, it's the ballast or ignitors
Old Apr 16, 2007 | 07:21 PM
LukieLuc's Avatar
They are gone, blown i think it might be the ballast, call them up and use the warranty
Old Apr 16, 2007 | 07:26 PM
Default Re: HID problem (prelude1897)
Which part are the ignitors?
Old Apr 16, 2007 | 08:50 PM
B18c5__Owns's Avatar
From: I Bet You Really Want To Know Where In, NJ, USA
this happened to a buddy of mine. He was able to change the fuse and it worked again. I dunno how the mchullahs work
Old Apr 16, 2007 | 09:00 PM
Default Re: HID problem (B18c5__Owns)
what fuse did you change ?
Thanks
Old Apr 19, 2007 | 12:54 PM
LukieLuc's Avatar
the headlight fuse in your engine bay, another thing if that fuse is 20amps its going to act up put it up to like a 25 or 30
Old Apr 19, 2007 | 01:29 PM
mattsnooz's Avatar
Default Re: HID problem (LukieLuc)
yeah, if they run off the same circuit you might wanna use a slightly higher rated fuse (providing the wires in other system can handle the added current, which im not sure). read how much watts they put out, post it and i will tell you how much higher of a fuse you'd need to prevent blowing fuses.
Old Apr 19, 2007 | 01:41 PM
Default Re: HID problem (mattsnooz)
Yeah I finally realized that the fuse was the problem when i put my stock bulbs back in and nothing lit up.
I raised the fuse to 20A from a 15A and now it works perfectly fine.
Thanks guys for your help
Old Apr 19, 2007 | 03:06 PM
IMPORTWERKZ's Avatar
up
Old Apr 19, 2007 | 03:20 PM
thelonerangers's Avatar
Default Re: (IMPORTWERKZ)
um, i dnt know much about car electric. but i know house electric, unless the wire is rated to handle 20 amps u shouldnt really fuse it at 20 amps.
Old Apr 19, 2007 | 04:04 PM
Default Re: (thelonerangers)
Well the fuse kept burning out when I had the 15A in there so, I updgraded to the 20A.
Now it works fine
Old Apr 19, 2007 | 09:33 PM
madcatz's Avatar
Im supprised you havent fried something else out.....upping the amps means its conducting more electricity at either start up or its grounding somewhere. Ohms law, learn it.....auto/home/life its the same no matter what
Old Apr 19, 2007 | 10:38 PM
Default Re: (madcatz)
gee thanks
Old Apr 19, 2007 | 11:10 PM
The Phil's Avatar
Default Re: (Inextricabledrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inextricabledrvr &raquo;</TD></TR><TR><TD CLASS="quote">gee thanks </TD></TR></TABLE>
You know, he's not trying to be a dick as much as warn you about it.
I would wire a relay in with some heavier gauge wire that is rated to support the HIDs.
Old Apr 19, 2007 | 11:52 PM
madcatz's Avatar
no, I was trying to be a dick, AND warn him about it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the phil &raquo;</TD></TR><TR><TD CLASS="quote">wire a relay</TD></TR></TABLE>
Best advice thus far
Take your normal signal wire for your Headlamps (ON) and run that to power the relay. Take a direct FUSED line from the battery, or splice via the headlights fuses. I would find an extra fuse block that will support the fuse you would need, and run that. Your ballast will run via 12v DC. Run your 12v to the input of the relay, and then run your output to the Positive of the Ballast. Then Ground Appropriately. Run proper guaged and amperage wire to the ballasts from the relay. That way you wont fry out your stock wires, and if you go back to stock you wont have to cut and slice too much. If you do it right you should just be able to remove the HID setup and relay setup and call it a day, going back to stock
Old Apr 23, 2007 | 11:45 PM
bizzy930's Avatar
The obvious way to narrow down the problem to find out whether its the bulb or ballast/ignitor is to switch the bulbs between the two and see if the same problem continues with the good bulb and whether or not the so called bad bulb is still acting up. Bad bulbs can cause flickering as well. How do i know this? From personal experience.
Old Apr 24, 2007 | 06:54 AM
preludefien
Guest
Posts: n/a
Default Re: HID problem (bizzy930)
did you have a good connection with the oem connector that plugs in...i have to replace my connector because of the same problem. it just wasnt getting a good connection..
vtek9
Lighting
Dec 20, 2007 02:26 PM
RSX_TypE-1
17
Jun 21, 2006 07:23 PM
damarksman
Sep 14, 2001 08:41 AM
GettaluvR
Aug 6, 2001 11:03 PM
