H22/H23 Crank Pulley
Old 04-18-2007, 11:51 PM
snowblind7x's Avatar
Default H22/H23 Crank Pulley
Are a H22 and H23 crank pulley the same?
Old 04-18-2007, 11:53 PM
Black-Engine's Avatar
Default Re: H22/H23 Crank Pulley (snowblind7x)
No, H23 one is bigger
Old 04-19-2007, 12:15 AM
Default Re: H22/H23 Crank Pulley (Black-Engine)
alright. thanks
Old 05-12-2007, 10:21 AM
preludefien
Guest
Posts: n/a
but they both work for ea engine
Old 05-12-2007, 10:24 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Engine &raquo;</TD></TR><TR><TD CLASS="quote">No, H23 one is bigger</TD></TR></TABLE>
wtf?
wrong.
the h22 pulley has an extra rib on each belt, that is the only difference, they're basically interchangeable.
Old 05-12-2007, 12:06 PM
Ludster's Avatar
Make sure you get the right alternator and belt combo as well.
Old 05-12-2007, 06:22 PM
Hawkze_2.3's Avatar
Also no from me. The H23 is technically smaller, because it has one less rib on it. That is the difference, H23 = 5 ribs, H22 = 6 ribs.
Old 05-13-2007, 02:13 AM
Well, we measured both... H23 pulley was 3 cm larger then the H22, so the h22belt on the H23 pulley on my H22 engine won't fit (besides the ribs ofcourse)
I measured the H23 pulley from my Dutch Prelude ang the JDM H22 pulley...
Old 05-13-2007, 01:17 PM
jdmlude5
Guest
Posts: n/a
Default Re: H22/H23 Crank Pulley (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
wtf?
wrong.
the h22 pulley has an extra rib on each belt, that is the only difference, they're basically interchangeable.</TD></TR></TABLE>
x2
Old 05-13-2007, 05:29 PM
Hawkze_2.3's Avatar
Default Re: (Black-Engine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Engine &raquo;</TD></TR><TR><TD CLASS="quote">Well, we measured both... H23 pulley was 3 cm larger then the H22, so the h22belt on the H23 pulley on my H22 engine won't fit (besides the ribs ofcourse)
I measured the H23 pulley from my Dutch Prelude ang the JDM H22 pulley...</TD></TR></TABLE>
Really?...wierd. Wonder why they're different...
Old 05-13-2007, 06:54 PM
spun311's Avatar
Default Re: (Hawkze_2.3)
Yes, I am running an h23 pulley on my h22 right now and i am running a belt with one less rib than it should have and i actually havent had any problems. Its kinda ghetto but why fix whats not broken yet.
Old 05-13-2007, 10:09 PM
JT
JT's Avatar
The H23 is slightly larger in dia than the H22 and has one less rib on the inner pulley section. The outer pulley has the same amount of ribs as the H22. The H23 is also slightly lighter in weight. I measured and weighted both during the swap.
Old 05-13-2007, 10:11 PM
mgags7's Avatar
Default Re: (JT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT &raquo;</TD></TR><TR><TD CLASS="quote">The H23 is slightly larger in dia than the H22 and has one less rib on the inner pulley section. The outer pulley has the same amount of ribs as the H22. The H23 is also slightly lighter in weight. I measured and weighted both during the swap.</TD></TR></TABLE>
Interesting
Its more than fine to run a 5rib belt on a 6rib alternator/ac, its not gonna hurt anything.
Old 05-13-2007, 11:51 PM
Default Re: (JT)
^^ Thx... I did the same =&gt; same conclusion
liljimmy14
09-04-2010 03:00 AM
Black-Engine
04-20-2007 06:11 AM
blacklude94
11-14-2005 04:08 PM
delslowh23
09-06-2004 04:33 PM
crj_lll
06-17-2003 08:56 PM
Quick Reply: H22/H23 Crank Pulley
