VSS ABS problem
Old Aug 23, 2007 | 08:37 PM
prelude_93vtec's Avatar
Default VSS ABS problem
hey everyone. i pulled the abs code and i got 4-4 which is right rear wheel VSS. well im only 15 lol and i know what it does but i dont know where it is or how it looks. what can be wrong with it? the speedo is working perfect but i dont know if the ABS is. can someone show me how to change it out and how it looks and what not? thanks
Old Aug 24, 2007 | 04:10 AM
Speedra500's Avatar
Default Re: VSS ABS problem (prelude_93vtec)
you could either get a helms, or pull the wheel off and follow and wires to the wheel hub
Old Aug 24, 2007 | 12:30 PM
Default Re: VSS ABS problem (Speedra500)
ya i would do that but i have no idea where its located at and how to remove it or anything lol. is it hard to take it off?
Old Aug 24, 2007 | 02:22 PM
92_civic's Avatar
sounds like you need to do some research bud...buy a helms manual, or a factory manual and start reading...
changing a speed sensor is a pretty straight forward, remove the wheel, examine the hub/rotor area, there should be some wires running from the hub to the body, follow that wiring to the hub where you will find the sensor bolted to hub ( I believe it is a single 10mm bolt) You'll probably have to fight with it/destroy it to remove due to corrosion, clean the hole in the hub and the mounting surface for the sensor and install the new sensor
if you need a better explanation than that, a manual is going to be your best bet, good luck
wildoutwhitegsr
Sep 2, 2016 04:33 PM
wildoutwhitegsr
Apr 29, 2013 09:06 AM
ColdScript
Jul 18, 2009 09:55 AM
JLange
Mar 12, 2003 06:03 AM
vtec_addict
Nov 11, 2002 10:10 AM
